Page 14 of 17 FirstFirst ... 4567891011121314151617 LastLast
Results 131 to 140 of 164
Thread: RELEASE: Map Monkey v1.1.3
  1. #131
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    Sorry if i'm covering old questions but just wondering if theres a way to convert the measurements to metric via the software?
    CAR INFO HERE
    "He who dies with the most toys, wins".
  2. #132
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by vxcarpc
    Have you checked all the settings?
  3. #133
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    It's in the settings of D3. Go menu / settings / general settings. There is a units system setting. Choose MPH or km/h
  4. #134
    Apr 2005
    hi there,
    i have an odd problem: when i launch map monkey the normal way everythign works. it reconnects to GPS at startup, displaying my correct position. Within Centrafuse however, the location-cursor jumps to my current location and then, half a second later, jumps to a totall different adress in my city. when i start to drive the map rotates according to my car-movement but the location is fixed to this specific adress.
    I just drove to this adress and guess what happened: the location-cursor jumped irradically somewhere inside a nearby sea...
    Then, when i drove back, about 100meters away from this strangly fixed location, i jumped back from the see to the mysterious location.
    has anyone encountered a similar phenomenon or has a fix? As i said... normal mapmonkey works like a charm... (despite it also Starts at the mysterious adress but THEN jumps to my correct location)
    thanks
    My Car-PC: Athlon XP Barton 2800+, 512 MB Ram, 60GB HDD, Radeon 9800 Pro, 7" Touchscreen MM400 :)
  5. #135
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    If we have these gps values E023°51.232', N038°10.564' how can we convert them to such values that will be recognised by MM?
  6. #136
    Jan 2005
    Merseyside
    try
    longitude is the E degrees ( 23 ) + mins 51.232/60.0 which = 23.8538666
    latitude is the N degrees ( 38 ) + mins 10.564/60.0 which = 38.1760666
  7. #137
    Jan 2005
    Merseyside
    PS, i could be wrong, as I don't know what MM wants, but i'm assuming it's that.
  8. #138
    Jun 2004
    GREECE/Athens
    Thanx a lot!!
    I will try that tomorrow!!
  9. #139
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by baggers
    try
    That worked!!
    Thanx a lot!!
    Any chance anyone knows how I can get long/lat if I click on a destinator map through MM?? I want this in order to build Speed Cam database for Greece!! I don't have coordinates for all the cameras, but address/#!
  10. #140
    Jan 2005
    Merseyside
    I'm glad it worked for you DjBac
  1. Map Monkey v1.1.3 BETA 3
    By Ninja Monkey in forum Map Monkey
    Last Post: 03-29-2005, 08:50 AM
  2. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 05:43 PM
  3. Map Monkey : Screenshots here
    Last Post: 12-25-2004, 09:17 PM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 07:31 PM
