Is this possible?:(Quote:
Originally Posted by DjBac
Printable View
http://www.mp3car.com/vbulletin/mm-faqs/43617-using-go-home-feature.html
OOoppss. Thanx!:):)Quote:
Originally Posted by Bravellir
download link not working anymore ? mirror also down
Just when i wanted to download it too.. :tard:
just worked for me, had to download again because its allgone wrong!
Still got me problem, everytime I run it from the launcher and frodoplayer or just from the EXE it starts in setup everytime.
Hi all just new to this site so give me a break.
Can you use Map Monkey on windows 4.2 system.I have a transonic 6000T PNA with MN6 and have unlocked it to get into the system can I put the Map Monkey on a SDcard and run it through that or do I have to run it in the windows system, what do I have to do to make it work.
THANKS FOR THE HELP
MapMonkey is basically an interface to run destinator 3. By default destinator 3 is hard coded to run off the c:\ drive, so you can only run it fromt there.
Threrefore if the SDcard is not the C:\ drive it won't work.
*It may be possible to hack the exe to get it to run from another drive, but then you really need to know what yopu are doing to do it.
THANKS FOR THE INFO.
So it will run on Window 4.2 and I can just run it out of there I just have to find how to get it in on c drive or change it to another drive.
Do you think Mapmonkey is the best or are there other programs that are easier to put in and run with australia/sweden maps.
What do you mean by window 4.2?
It runs on windows 2000 and XP.
Vista with some difficulties, and possibly 9x
