I just opened it up in a hex editor and changed all the C:\destinatorapps\ to D:\destinatorappsQuote:
You mean a cracked DLL?
Printable View
1. I didn't put it there (nothing to do with my app), that's part of the SDK demoQuote:
Originally Posted by knubile
2. Why do you need to hit the X? Doesn't HOME do the same thing?
So you started using a newer SDK? I've never seen this message before. I wonder if my old sdk files will still work with your new release?Quote:
Think you can still allow me to install it in a specified location?
It's the same SDK, it just hasn't been modified to accept large maps (and the "Demo" message hasn't been removed)
There's nothing to stop you using a previous DLL, but I'm not advising that.
Edit: I'm not reuploading 16mb (forcing everyone who's downloading now to cancel) just so you can install to a different drive. Can't you install to C:\ and just copy it across?
Well, I was just testing that ;)Quote:
Originally Posted by Ninja Monkey
Anyway, Mapmonkey is now exactly build using the SDK, so the rest is up to the users and/or powerlock, NM didn't modify anything...
That's no problem. Do you I have to change a bunch or registry settings as well though? I'm not sure exactly what your install process does.Quote:
Nope, only things it creates outside of C:\DestinatorApps are start menu shortcutsQuote:
Excellent. Thanks for the help. Trying it now.
I just downloaded 16 mb full install map monkey backed up but then deleted my old apps clicked on map monkey it and says a higher version of map monkey is installed. :nw:
