1. I didn't put it there (nothing to do with my app), that's part of the SDK demoOriginally Posted by knubile
2. Why do you need to hit the X? Doesn't HOME do the same thing?
I just opened it up in a hex editor and changed all the C:\destinatorapps\ to D:\destinatorappsYou mean a cracked DLL?
Destinator 3 For PC! - http://www.map-monkey.co.uk/
So you started using a newer SDK? I've never seen this message before. I wonder if my old sdk files will still work with your new release?I didn't put it there (nothing to do with my app), that's part of the SDK demo
Think you can still allow me to install it in a specified location?
It's the same SDK, it just hasn't been modified to accept large maps (and the "Demo" message hasn't been removed)
There's nothing to stop you using a previous DLL, but I'm not advising that.
Edit: I'm not reuploading 16mb (forcing everyone who's downloading now to cancel) just so you can install to a different drive. Can't you install to C:\ and just copy it across?
Well, I was just testing thatOriginally Posted by Ninja Monkey
Anyway, Mapmonkey is now exactly build using the SDK, so the rest is up to the users and/or powerlock, NM didn't modify anything...
That's no problem. Do you I have to change a bunch or registry settings as well though? I'm not sure exactly what your install process does.Can't you install to C:\ and just copy it across?
Nope, only things it creates outside of C:\DestinatorApps are start menu shortcutsOriginally Posted by knubile
I just downloaded 16 mb full install map monkey backed up but then deleted my old apps clicked on map monkey it and says a higher version of map monkey is installed.![]()
