Page 4 of 17 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 164
Thread: RELEASE: Map Monkey v1.1.3
  1. #31
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by sajeev
    I bought D3 UK version and was using your version 1.1.2. If I want to use the final version 1.1.3 what exactly do I need to do. (Officially) I have downloaded it already.
    I changed the dest dll on 1.1.3, replaced it with the one from 1.1.2 without any problems.
    This got rid of the message on screen regarding the SDK.
    How I installed the 1.1.3 was that I removed old destinator apps folder from c drive then installed the new one.
    Is this the correct way?
    Can you please put me right.
    Thanks.
    That should work fine...I can't tell from your post, but are you having problems with doing it that way?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #32
    FLAC mauri's Avatar
    Jan 2004
    Good good work, Ninja
    To work Map Monkey embedded to Mediacar or the new Road Runner ,the setup correct , EXTERNAL ,and "search string "its the old *Destinator 3* or *Map Monkey* ?
    To don't wiev the nag bar ,set to "Fullscreen" ?
    All its ok !!!!!
    Mauri
  3. #33
    The land of polar bears and nekkid blonds
    So now that you've done it the official route, have destinator given you access to a newer SDK where TMC is enabled ?
    /M
  4. #34
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Maximus
    /M
    Is there a newer SDK where TMC is enabled ?
  5. #35
    Feb 2004
    got to say GREAT WORK ninja!! ivīe got it working perfectly love the new "monkey" look to it
  6. #36
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Hi,
    stupid question, how do i remove the huge yellow speed indicator ?
    Until now, i thought removal of this would be possible in the final release,
    but i canīt find it. Where is it hidden ?
    - Superbowl
    i never drink water cos fish ***** in it. (w.c. fields)
  7. #37
    Aug 2003
    Warrington, UK
    Quote Originally Posted by superbowl
    Hi,
    - Superbowl
    I haven't had chance to document this in the FAQ yet, but if you open the SKIN.INI of the skin you're using and change this line
    SpeedColor=-1
    That should get rid of it
  8. #38
    Newbie Tribune-Maximus's Avatar
    Dec 2004
    @ Map Monkey
    Really great work with the v1.1.3 Release !!!
    Have only two problems !? Hope you can help with this!!
    1. The final seems to be no longer embedded in FP!? Can't get it work lile the Beta3
    2. Speed Display is only MPH/Yard ...no change when i set to Metric in Setup !?
    What's the way to solve this little cosmetic 'problems'???
    REGARDS
    tribune
    Shuttle FE22 P3-800MHz C3, 512MB RAM
    Morex 3688 black, CarTFT-M1-PowerSupply
    Lilliput 7" Touchscreen TFT Monitor
    Holux GM-210 GPS USB Device
    Ovislink WL5480 WLan Device / 8dbi
    24Bit USB Soundcard
  9. #39
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Tribune-Maximus
    @ Map Monkey
    REGARDS
    tribune
    Which setup screen did you use to change it to metric?
  10. #40
    FLAC mauri's Avatar
    Jan 2004
    No, embedded to Mediacar MM appears correctly,but covers completely the bar aloft of MC, as if and launched in stand-halone.
    Setting MC with EXTERNAL, and string * map * or * map monkey * but don't work
    Mauri
  1. Map Monkey v1.1.3 BETA 3
    By Ninja Monkey in forum Map Monkey
    Last Post: 03-29-2005, 09:50 AM
  2. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 06:43 PM
  3. Map Monkey : Screenshots here
    Last Post: 12-25-2004, 10:17 PM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
