a screenshot if you will, mauri :)
Printable View
Simple,the MM apperas some whit the launch stand-alone.
MM work correctly,only embedded to mediacar have the problem.
I launch MC, click on GPS, appears for one second the MC bar, MM apperas and cover the bar :confused:
The screen its to MM embedded to MC,the same of launch in stand-alone mode
Mauri
@ Map Monkey
First Problem solved...HDD failure :o) ...it's just working fine with Km/h :)
...but like Mauri said...the final vers. launches as standalone also in FP
...that's what i meant!
Is there any option to set to solve this??
REGARDS
tribune
Try setting the window title as the full "Map Monkey - [GPS]" ?
Tested for "Search string "whit :
map
Map
Map Monkey
"Map Monkey"
*map*
*Map*
*Map Monkey*
*Map Monkey - [GPS]*
Map Monkey - [GPS]
Don't work, not se resize to view the bar of MC
Mauri
Try re-downloading this and then setting the search string to:Quote:
Originally Posted by mauri
Map Monkey -*
anyone can run ninja monkey's frontend in linux with wine/cedega/crossover wine?
All OK Ninja, fixed the problem!Quote:
Originally Posted by Ninja Monkey
Your hare the best :-))
Mauri
Who the hell is Map Monkey???Quote:
Originally Posted by Tribune-Maximus
It's Ninja Monkey dammit. :D
Make sure this thread is not open if you use the string *Map Monkey*.
This ie session has just got embedded into mediacar :D
otherwise the embedding into Media Car works fine for me.
