Page 5 of 17 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 164
Thread: RELEASE: Map Monkey v1.1.3
  1. #41
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    a screenshot if you will, mauri
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #42
    FLAC mauri's Avatar
    Jan 2004
    Simple,the MM apperas some whit the launch stand-alone.
    MM work correctly,only embedded to mediacar have the problem.
    I launch MC, click on GPS, appears for one second the MC bar, MM apperas and cover the bar
    The screen its to MM embedded to MC,the same of launch in stand-alone mode
    Mauri
  3. #43
    Newbie Tribune-Maximus's Avatar
    Dec 2004
    @ Map Monkey
    First Problem solved...HDD failure ) ...it's just working fine with Km/h
    ...but like Mauri said...the final vers. launches as standalone also in FP
    ...that's what i meant!
    Is there any option to set to solve this??
    REGARDS
    tribune
    Shuttle FE22 P3-800MHz C3, 512MB RAM
    Morex 3688 black, CarTFT-M1-PowerSupply
    Lilliput 7" Touchscreen TFT Monitor
    Holux GM-210 GPS USB Device
    Ovislink WL5480 WLan Device / 8dbi
    24Bit USB Soundcard
  4. #44
    Aug 2003
    Warrington, UK
    Try setting the window title as the full "Map Monkey - [GPS]" ?
  5. #45
    FLAC mauri's Avatar
    Jan 2004
    Tested for "Search string "whit :
    map
    Map
    Map Monkey
    "Map Monkey"
    *map*
    *Map*
    *Map Monkey*
    *Map Monkey - [GPS]*
    Map Monkey - [GPS]
    Don't work, not se resize to view the bar of MC
    Mauri
  6. #46
    Aug 2003
    Warrington, UK
    Quote Originally Posted by mauri
    map
    Map
    Map Monkey
    "Map Monkey"
    *map*
    *Map*
    *Map Monkey*
    Map Monkey - [GPS]
    Mauri
    Try re-downloading this and then setting the search string to:
    Map Monkey -*
  7. #47
    Constant Bitrate forevertheuni's Avatar
    Jul 2004
    Portugal,Mealhada
    linux
    anyone can run ninja monkey's frontend in linux with wine/cedega/crossover wine?
  8. #48
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Ninja Monkey
    Map Monkey -*
    All OK Ninja, fixed the problem!
    Your hare the best :-))
    Mauri
  9. #49
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Tribune-Maximus
    @ Map Monkey
    Who the hell is Map Monkey???
    It's Ninja Monkey dammit.
  10. #50
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    No, embedded to Mediacar MM appears correctly,but covers completely the bar aloft of MC, as if and launched in stand-halone.
    Setting MC with EXTERNAL, and string * map * or * map monkey * but don't work
    Mauri
    Make sure this thread is not open if you use the string *Map Monkey*.
    This ie session has just got embedded into mediacar
    otherwise the embedding into Media Car works fine for me.
  1. Map Monkey v1.1.3 BETA 3
    By Ninja Monkey in forum Map Monkey
    Last Post: 03-29-2005, 09:50 AM
  2. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 06:43 PM
  3. Map Monkey : Screenshots here
    Last Post: 12-25-2004, 10:17 PM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
