I have the same problem (as your screenshot) Mauri. How did you fix it ?Originally Posted by mauri
Wizz
Guino fixed it
See my car and donate for spinning logos at www.ildena.it/carpc
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
Originally Posted by wizz
what string are you using to embed?
and what is your exe path?
@WizzOriginally Posted by wizz
Download the new hotfix by Ninja,
http://www.mp3car.com/vbulletin/show...5&postcount=46
replace the Map Monkey.exe in C.\DestinatorApp\Map Monkey
Open the Mediacar setting utility,set to:
EXTERNAL
Path:C:\DestinatorApps\Map Monkey\MapMonkey.exe
Window search string:Map Monkey -*
Work ok![]()
Mauri
Hi NM,
I can't seem to get the final version installed.
it sais there is already a newer version installed..
cheers
Originally Posted by Vik
uninstall beta 1.3,or whatever version you have, from add remove programs
CarPuter ProgressO meterO
[+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
visit me on the web at
http://gozips.uakron.edu/~cmk23/
looks like when closing MM from keyboard, I need to press Alt+F4 key combination twice to get MM fully closed. First Alt+F4 only closes map "window" part while its backgroung remains alive. I have to press Alt+F4 again in order to clos MM completelly. Is there a way to fix it?
Well done and thanks... may well send a donation when I have the money how ever it would be nice if you could get a legal way of buying this properly though PL... I'd be willing to pay for that NP.
Terran
PS Just out of intest - does any one know how many 'proper' users of MM are out there. ( Interprate 'Proper' what ever way you want)
This is a problem with the SDK. The only way I can fix this would be to catch ALT+F4 before it gets sent to the map window. You can do this yourself by opening Hotkeys.INI and changing this line:Originally Posted by mpattonm
Hotkey00=Local,FE_QUIT,{ALT},F4
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Hi Mauri,Originally Posted by mauri
The only thing I was missing from above was the search string.
But still can't get it right![]()
If I set Maximised the titlebar is still there
If I set Fullscreen there is a gap at the bottom with the taskbar in it
If I hide the taskbar there is still a gap
What am I doing wrong ?![]()
Wizz
