Page 7 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 61 to 70 of 164
Thread: RELEASE: Map Monkey v1.1.3
  1. #61
    FLAC mauri's Avatar
    Jan 2004
    Whit the setting posted for Mediacar MM work ok in embedded,fix the problem.
    But one little problem i have see:
    Embedded to MC the two button of scroll UP/DOWN don't work,the OSK its ok.
    In stand-alone MM the scroll button work ok.
    Setting in MM utility "size and positon " normal",select the " size e position on startup", select " use custom setting," "800x600"
    This settings work ok in my PC.
    Mauri
  2. #62
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by mauri
    Mauri
    Mauri,
    These are the settings I have, but in normal & maximised the Map Monkey - [GPS] title bar still shows. In Fullscreen it doesn't but I have the windows taskbar showing.
    HELP !
    EDIT: The settings work OK on my Laptop but not my Carpc.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  3. #63
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Enforcer
    what string are you using to embed?
    and what is your exe path?
    I have run Mediacar setup and edited to the new path and string *Monkey Map -* , but I still get "Monkey Map - [GPS]" title bar showing.
    Wizz
  4. #64
    Newbie Colt's Avatar
    Jan 2005
    Netherlands
    Anyone know how to remove the "Destinator SDK not for sale" message?
    Or do I have to buy Destinator to remove that?
  5. #65
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Colt
    SEE
    "Map not registered" and "Destinator SDK not for sale" messages
    Wizz
  6. #66
    May 2003
    UK
    NM - Still no GPS after standby resume !
    Using standard BU-303 with usb>serial driver
    D2 is fine
    any ideas?
    James
    www.digital-car.co.uk - The UK CarPC Forum
  7. #67
    Constant Bitrate mpfjr's Avatar
    Jun 2004
    Corona, CA
    Hey, I own Destinator 3 and Iguidance 2.0(which I have been using) but I just found out about mapmonkey today!! Now I have downloaded ver 1.13 and of course I don't have the modified sdk file.
    Which files get modified? is it just DestDLL.DLL? Or are there others? What needs modified? if you can't post the answer please pm me. I do own the software so I feel I should be able to make the changes and use it with map monkey. Iguidance is just not very touch screen friendly even after all the theme.ini's and hacking the exe.
    PM me instructions please!
  8. #68
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by wizz
    Wizz
    try *Map Monkey*
    works for me
  9. #69
    FLAC mauri's Avatar
    Jan 2004
    Wizz
    I have write in my old post for correct string:
    Map Monkey -*
    Write as i have done me
    Mauri
  10. #70
    Newbie Tribune-Maximus's Avatar
    Dec 2004
    @ NM
    Problem with embedding MM in FP is not solved yet...for me
    Have read that other users have the same thing...other descriptions, but
    the same problem! (full MM window w/o Titlebar)
    Is there any way to fix it??
    ..the satfix does not fix it...same with the external-gps-solution
    REGARDS
    tribune
    Shuttle FE22 P3-800MHz C3, 512MB RAM
    Morex 3688 black, CarTFT-M1-PowerSupply
    Lilliput 7" Touchscreen TFT Monitor
    Holux GM-210 GPS USB Device
    Ovislink WL5480 WLan Device / 8dbi
    24Bit USB Soundcard
  1. Map Monkey v1.1.3 BETA 3
    By Ninja Monkey in forum Map Monkey
    Last Post: 03-29-2005, 09:50 AM
  2. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 06:43 PM
  3. Map Monkey : Screenshots here
    Last Post: 12-25-2004, 10:17 PM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
