Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Going from Beta3 to realease of 1.1.3
    Jun 2004
    Problem? Or just sats not locked?
    I just uninstalled Beta3 adn deleted C:\destinatorapps (backed up maps and .dll) and installed map monkey. This pops up every 5 seconds or so, I'm inside on the laptop so my GPS isnt locked (barely seeing 1 sat) and its snowing outside so im not gonna go out and stand there with the laptop.....
    Error Details:
    Number: -2147211500
    Description: Index out of bounds
    Source: AdvGPS_Satellites
    Version: 1.1.340
    HelpContext: 1000440
    HelpFile:
    LastDllError: 0
    Is this a common thing since the program has No idea where it is on the map or do i have a problem with install? It does this with and withough Adv GPS checked and before and after maps added
    Andy
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Yep, it's because you aren't seeing any satellites, it shouldn't happen with advanced gps off though
    Can't believe I missed this! Going to have to release a fix now!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Oct 2004
    Australia
    Hi
    I'm also getting this error.
    The messages goes away if I don't use 'Advanced GPS'. Enable that option, and the error box keeps popping up.
    thanks
    Aug 2003
    Warrington, UK
    Can you guys try this:
    http://homepage.ntlworld.com/shaunjo...key_SatFix.zip
    Should sort both the satellite problem (though untested) and the error when closing Map Monkey via the 'X'
    Oct 2004
    Australia
    Quote Originally Posted by Ninja Monkey
    Nope -
    Error Details:
    Number: -2147211500
    Version: 1.1.342
    HelpFile:
    LastDllError: 0
    Although I am sitting in a basement carpark with no GPS signal.
    Aug 2003
    Warrington, UK
    Oct 2004
    Australia
    Yes - that did it.
    No more error message popup.
    Thanks.
    Jun 2004
    Works
    Awesome job!
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    NM... sorry for the PM i sent ya, i didnt see your latest thread about PM's.... here ya go... if i use a big map (all of western US), it shows incorrect GPS info. It thinks im somewhere completely different, not to mention it always says that i have "0" satellites acquired all the time. I set the correct COM port and 4800. Any ideas? I can now confirm that its doing that for all the maps i use, even smaller maps. It doesnt show me where i am correctly. (random location)
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
    Aug 2003
    Warrington, UK
    Are you sure you have a lock?
  1. 1.1.3 BETA(3) - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 01-30-2005, 07:14 AM
  2. 1.1.3 BETA3 Hotfix 3
    Last Post: 01-23-2005, 10:16 AM
  3. 1.1.3 BETA3 Hotfix 2
    Last Post: 01-14-2005, 06:52 PM
  4. New Destinator Skin - download 1.1.3 beta3
    By mick-uk in forum Map Monkey
    Last Post: 01-13-2005, 05:20 AM
  5. 1.1.3 BETA3 Hotfix 1
    Last Post: 01-12-2005, 05:16 PM
