Results 1 to 3 of 3
Thread: Problem embedding Map Monkey
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Exclamation Problem embedding Map Monkey
    I opened an identic thread in Road Runner section.
    After launching Map Monkey embedded the view window (the one where you choose 2D, 3D ecc) disappears. Instead of it appears the little square of fig 1 that remains also after closing RR. The problem is that if I don't change skin and restart Map Monkey the view window doesn't work either in stand alone mode. What's the matter?
    See my car and donate for spinning logos at www.ildena.it/carpc
    FLAC mauri's Avatar
    Jan 2004
    Another problem:
    In stand-alone mode Map Monkey work all ok, but embedded to Mediacar or Road Runner the scroll button UP-DOWN don't work,ok the OSK.
    EDIT:i have installed the hotfix, write the correct string posted by Ninja in Mediacar,but same problem,scroll button don't work.
    Mauri
    Dec 2004
    Italy
    Fixed whit this
    Quote Originally Posted by Ninja Monkey
    Try re-downloading this and then setting the search string to:
    Map Monkey -*
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  3. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 09:27 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
