Results 1 to 8 of 8
Thread: Switching maps problem
    May 2004
    When I go to switch maps it doesn't show any of the other maps I have installed under c:\destinatorapps\destinator. I know I have maps there in folders and unzipped.
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Be sure you have a different wce.txt in all your map folder. In the first row of this file there is written the name of the map. If you can load map over 3MByte but there's no way to use your map probabli this is the solution of your problem...
    See my car and donate for spinning logos at www.ildena.it/carpc
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by tmar89
    No you haven't...if you did, they would work!
    Variable Bitrate Goose's Avatar
    Dec 2002
    Europe
    The reason is that you are using a bigger maps then 3MB.
    May 2004
    I didn't have the WCE.txt files and when I go to load the map, the blue screen comes up saying my map isn't registered. And if you can't have maps larger than 3MB, isn't that a small amount of data to show? For instance, USA5 is 216MB
    Oct 2003
    Madrid
    Hmmm, you've found a bug!! What can we do?
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Hehe I knew this post will appear one day.
    May 2004
    ugh, I admit I'm an idiot. I should have read the sticky post first before posting this. This thread should be deleted.
  1. Replies: 12
    Last Post: 08-26-2008, 07:37 AM
  2. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  3. Destinator 3 with Australian maps
    By JayKaye in forum GPS
    Last Post: 08-07-2004, 08:54 PM
  4. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  5. Replies: 8
    Last Post: 12-31-2002, 12:37 PM
