wow it works! THX 4 this fast support!
NM, thanks for your continuing hard-work, great stuff! :nw:
How does this launcher work with Frodo? Do I call the launcher exe instead of the original map-monkey one? Also, what does this correct? I was hoping this would address the “Title-Bar” issue embedding it with Frodo, but it’s still there… :confused:
Any feedback you can provide would be appreciated…
Great... works great now in CF!! This was my missing part for software... (now the rest :p )
NM
Got it working now.
But when I exit MM with the X I get a MMLauncher Run-time error' - 1934 (fffff872)': Map Monkey not found or not listening.
This is behind the Mediacar Frontend. :confused: :confused:
Wizz
I don't quite understand how to use it with Frodo. Could someone please explain it to me :( ? Also which of the two exes to use (I guess "MapMonkeyLauncher.exe") ?
Yes, like the first post says, call the launcher instead of map-monkey. It should address the title-bar issueQuote:
Originally Posted by xcntrk75
Sorry guys it wasn't working properly with frodo. Should be now :)
Quote:
Originally Posted by Ninja Monkey
works great!.
NMQuote:
Downloaded it again, but it was the same file ?
Same Problem:- Run-time error 1934 Map Monkey not found or not listening (when I exit using X)
Wizz
Again, again! :DQuote:
Originally Posted by wizz
