Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 107
Thread: Map Monkey Launchers (Fixes for Frodoplayer, Centrafuse, Mediacar...)
  1. #11
    Dec 2004
    wow it works! THX 4 this fast support!
  2. #12
    Newbie xcntrk75's Avatar
    Jan 2005
    MD
    NM, thanks for your continuing hard-work, great stuff!
    How does this launcher work with Frodo? Do I call the launcher exe instead of the original map-monkey one? Also, what does this correct? I was hoping this would address the “Title-Bar” issue embedding it with Frodo, but it’s still there…
    Any feedback you can provide would be appreciated…
  3. #13
    Low Bitrate Bokky's Avatar
    Jan 2005
    Ham, Belgium
    Talking
    Great... works great now in CF!! This was my missing part for software... (now the rest )
    EPIA M10K, 512MB RAM, 60GB
    [##########] 100% (since 1 March 2005)
    snowboarding.be - bokky.com
  4. #14
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Launcher
    NM
    Got it working now.
    But when I exit MM with the X I get a MMLauncher Run-time error' - 1934 (fffff872)': Map Monkey not found or not listening.
    This is behind the Mediacar Frontend.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  5. #15
    Aug 2004
    Germany
    I don't quite understand how to use it with Frodo. Could someone please explain it to me ? Also which of the two exes to use (I guess "MapMonkeyLauncher.exe") ?
  6. #16
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by xcntrk75
    Yes, like the first post says, call the launcher instead of map-monkey. It should address the title-bar issue
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  7. #17
    Aug 2003
    Warrington, UK
    Sorry guys it wasn't working properly with frodo. Should be now
  8. #18
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    Quote Originally Posted by Ninja Monkey
    works great!.
    CarPuter ProgressO meterO
    [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
    visit me on the web at
    http://gozips.uakron.edu/~cmk23/
  9. #19
    Nov 2004
    Leicestershire UK
    Try downloading it again
    NM
    Downloaded it again, but it was the same file ?
    Same Problem:- Run-time error 1934 Map Monkey not found or not listening (when I exit using X)
    Wizz
  10. #20
    Aug 2003
    Warrington, UK
    Quote Originally Posted by wizz
    NM
    Wizz
    Again, again!
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 37
    Last Post: 03-06-2005, 11:17 PM
  3. Replies: 3
    Last Post: 02-03-2005, 01:11 PM
  4. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 10:52 PM
  5. Centrafuse Launcher (Fixes Map Movement)
    Last Post: 02-02-2005, 03:53 PM
