Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 107
Thread: Map Monkey Launchers (Fixes for Frodoplayer, Centrafuse, Mediacar...)
  1. #21
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    Again, again!
    Will Do, Will Do!
    EDIT: Thanks..Thanks..Thanks..
    Works Fantastic......................
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  2. #22
    Newbie Trudge's Avatar
    Nov 2003
    Tasmania, Australia
    Excellent work NM.
    Works like a charm.
    Thanks a lot!
    '94 Mazda T3500 Bus, Lilliput 7", Mouse GPS, 1GHz TC1100 Tablet PC, Inverter, HUGE Spare battery, Smart Charger, Road Runner, FreeDrive.
  3. #23
    Sep 2003
    Vic. Australia
    Mine won't fullscreen in frodoplayer. It just sits on top of frodoplayer and isn't full screen.
  4. #24
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by grahamrb
    Have you changed the path in frodoplayer.ini to point to MapMonkeyLauncher.exe?
    Also, have you downloaded it since I said I fixed a problem with the frodo integration?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  5. #25
    Sep 2003
    Vic. Australia
    Yes, and yes. I just edited my previous post to include a screenshot. Presumably mapmonkey is suppose to be set up as an external gps app with the app exe as mapmonkeylauncher.exe?
  6. #26
    Aug 2003
    Warrington, UK
    No, choose "Destinator 3 (Ninja)" and then open frodoplayer.ini to change the default DEST3 path to "C:\DestinatorApps\Map Monkey\MapMonkeyLauncher.exe"
  7. #27
    Sep 2003
    Vic. Australia
    ok, thanks, will try that now.
  8. #28
    Sep 2003
    Vic. Australia
    awesome. Thanks, works great.
    One thing, when exiting map monkey, the launcher doesn't close. I assume thats just a bug because you are using the launcher to open up map monkey?
  9. #29
    Aug 2003
    Warrington, UK
    No, it isn't a bug...it should give you the option to double-click to relaunch D3 again.
    This is for frontends that won't relaunch the GPS app if it's been closed manually (e.g. the previous version of centrafuse)
  10. #30
    Sep 2003
    Vic. Australia
    ok, thats cool, just thought I would ask, just use to it exiting in frodoplayer.
    GREAT piece of software btw!!!!!!!!!!!!
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 37
    Last Post: 03-06-2005, 11:17 PM
  3. Replies: 3
    Last Post: 02-03-2005, 01:11 PM
  4. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 10:52 PM
  5. Centrafuse Launcher (Fixes Map Movement)
    Last Post: 02-02-2005, 03:53 PM
