Post a screenshot of your GPS settings screen in mediacarOriginally Posted by manung
hi nm,
before unloading the launcher, mapmonkey was perfectly set (or almost) in mediacar.![]()
After having unloaded the launcher it is not set more.'![]()
how can I do for returning back?.![]()
if not and' possible you explain me as I can do for making to work it?![]()
In enclosure some photos of my problem.
Thanks in advance.![]()
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Hey NM, thanks again for your support working through this issue with the Frodo front-end. I downloaded your most recent copy, specified the appropriate path to the launcher, and selected Destinator-3 (NM), yet still have this problem:
Map Monkey seems to be opening over the top of the launcher. When I resize this window, then exit and re-launch, it returns to this position. Even if you specify custom coordinates, or use “remember last settings” under the Map Monkey configurator. Any thoughts? Can the window position driven by the launcher be modified?
Thanks again for your support…![]()
all ok![]()
I have read this RELEASE: Map Monkey v1.1.3 and I have resolved.![]()
I attach photo.
thanks for the eternity support
P.S.
YOU HAVE INDEED A LOT OF PATIENCE
The fact that the window title in that screenshot says "Map Monkey" means that you're not using the LauncherOriginally Posted by xcntrk75
You need to open Frodoplayer.ini inside the frodoplayer installation folder and change MapMonkey.exe to MapMonkeyLauncher.exe
More with my Frodoplayer embedding problem.
What am I doing wrong here?
If anybody has any comments or can provide any assistance, please don’t hesitate!
First I’m downloading the latest launcher:
Then I’m changing the path in frodoplayer.ini:
Then I’m specifying the GPS app in frodoplayer, under settings:
When I select GPS, I get the launcher momentarily:
Then Map Monkey starts but is not embedded, simply overlays:
Somebody Please Help…![]()
Ahh ok...
Go into Map Monkey configuration and ENABLE plugin support
Ohhhh sweet success…!
That was it… Thank you Ninja Monkey!![]()
pics !Originally Posted by xcntrk75
[H]4 Life
I'm a lesbian too.
I am for hire!
I enabled Plugin Support under “Map Monkey – Configuration” as NM suggested:
And sweet Jesus it’s now embedded:
