Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 107
Thread: Map Monkey Launchers (Fixes for Frodoplayer, Centrafuse, Mediacar...)
  1. #41
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    I like your style. You should create screenshot walkthroughs of all my features
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #42
    Newbie xcntrk75's Avatar
    Jan 2005
    MD
    For developing such a great software app and supporting the community here, I would gladly take the time to do this for you…
    Problem is, with your presence here and on other forums, my allotted monthly bandwidth would be shot in a couple days…
  3. #43
    Newbie halve85's Avatar
    Feb 2005
    perfect, now its working fine!
    Thank YOU for fixing the problem!!!
  4. #44
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    NM - A great solution how ever ... seeing as it worked before you released it is it not a code problem ? Would it not be better to spend the time on fixing that rather than making a new app ?
    ( Don't get me wrong - I appciate what you do I'm just thinking out loud )
    Terran
  5. #45
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I would consider the launcher a patch, and the problem will be fixed in the new versions first alpha/beta
  6. #46
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by ccsnet
    Terran
    The problem it's that the name of the app changed and the frontends are not ready for this (neither they’re supposed to be - We all know why the name changed...)
    The solution it's on the frontends side of things, but nm, to avoid us guys having to wait for the frontends next releases, created this launcher.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  7. #47
    Oct 2004
    Netherlands
    Quote Originally Posted by Bravellir
    no in CENTRAFUSE its not the name, you can specify that but the way it embeds
    my destinator map resource down permanently
  8. #48
    Jan 2003
    Thinking lateraly... what about having a setting IN MapMonkey which can specify what sceen name to give ? Would save this prob in the future with apps. Got to be less work long term ?
    Just a thought
    Terran
  9. #49
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Ok so on my home pc everything works fine using the launcher to embed in MC... but when installed the exact same way in my car, the bottom half of the bottom row of buttons is off the screen...
    i have plugins enabled, MC is pointing to the launcher, and changed the line in mml.conf to mediacar.exe
    any ideas?
    Debating on installing a carpc in my Jeep.....
  10. #50
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by djXternal
    any ideas?
    I've had this too, it's because the Title bar is showing, so you have three components on screen, which forces the screen down. The title bar shouldn't show but I have found no way to eliminate it, so I have switched back to no launcher. This way there is only the title bar and navigation screen which fits the display ok. I've tried every combination of mediacar and monkey map config, with no luck. Just like you, I thought at first that this was the perfect solution because it worked great on my laptop. Im sure a fix will be available in time, just have to wait till then.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Replies: 37
    Last Post: 03-06-2005, 10:17 PM
  3. Replies: 3
    Last Post: 02-03-2005, 12:11 PM
  4. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 09:52 PM
  5. Centrafuse Launcher (Fixes Map Movement)
    Last Post: 02-02-2005, 02:53 PM
