thanks a lot been waiting fot this![]()
Here are a couple of launcher applications to help the problems with using Map Monkey in certain front ends.
This launcher has been mainly created to work with frodoplayer, but can be adapted to work in any environment. You can customise the launchers window title and the frontend application to search for (e.g. Frodoplayer, if frodo is found to be no longer running the launcher will close Map Monkey).
- FrodoPlayer/MediaCar Frontend Launcher
Mediacar users don't have to worry about closing map monkey before closing mediacar, the launcher will sort this all out for you.
To Configure
Frodoplayer users:
Don't need to do anything. The default window title is "Destinator 3 - [Dest3.1]" and the default application search is "frodoplayer.exe"
Mediacar etc users:
You need to run the launcher first to create a "mml.conf" file. Open this up in notepad and change the 2nd line to the name of the applications EXE file
Make sure you tell your frontend to run the Launcher as your GPS application rather than Map Monkey directly.
Edit: Also, make sure "Enable Plugin Support" is enabled in Map Monkey configuration
Download Here
Destinator 3 For PC! - http://www.map-monkey.co.uk/
my destinator map resource down permanently
If anyone's having any problems with the centrafuse launcher try downloading again
The file mml.conf modified for use whit MC and MapMonkeyLauncher in which folderi i must have put?
In practice to thing it serves (only if they are had some problems when he launches MC or and to use all of us)?
Excuse me but I have not understood well, MC work correctly to me whit MM....
Mauri
Then you don't have to use it! However some people have reported problems, so there ya goOriginally Posted by mauri
Sorry,
Can't seem to get it to work in MediaCar.
mml.config is changed to MapMonkey.exe
Mediacar has for GPS
C:\DestinatorApps\Map Monkey\MapMonkeyLauncher.exe
What Search string do I use ?
Run embedded or not ?
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
Whatever search string you want! You set the window title on the first line of mml.conf....also, you want to change the exe name in mml.conf to "MEDIACAR.EXE" not mapmonkey.exe!!Originally Posted by wizz
Using the CFD3Launcher.exe for Centrafuse I got the error:
Run-time error '13':
Type mismatch
what to do?
Download it againOriginally Posted by shinx
