Results 1 to 7 of 7
Thread: screenshot of ERROR GPS
    Constant Bitrate BOND007BE's Avatar
    Jul 2003
    belgium
    i got this situation a lot of times
    the SATS are GREEN but map is not showing.
    i am using RGM 2000 royaltek SIRF mode 38400
    the usb to com driver should it stay on 4800 bps
    the sun always shine
    Jan 2004
    Jersey/NY
    look at the bottom right of that screen shot, just about the "view" button.
    Those bars are red.. from what i remember, that means no good signal. Even though it can SEE 4 satellites, it's not getting a good signal from them.
    Someone please correct me if I'm wrong.
    Jul 2003
    belgium
    Quote Originally Posted by wizawuza
    i think the TOP is for ADVANCED GPS USAGE
    and the bottom is for normal USAGE
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Don't use 4800 for SiRF, that's most likely the problem. Try 38400
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jul 2003
    belgium
    Quote Originally Posted by Ninja Monkey
    the sirf mode is SET to 38400 , but in the USB 2 SERIAL convertor its speed is set to 4800
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I would try selecting Adv GPS and go from there .. sounds like maybe a sirf problem as well.
    Vik
    Vik is offline
    Newbie Vik's Avatar
    Nov 2004
    Belgium
    I seem to have the same problem?
    It shows the same, but I use nmea at 4800 (this is the only working config)
    Sometimes it works with advanced gps on and sometimes it doesn't at all...
    any ideas???
    Vik
  1. CD Ripping errors out...with screenshot
    By dmurray14 in forum Centrafuse
    Last Post: 01-24-2005, 10:14 AM
  2. XM Screenshot required...
    By MC_Stoo in forum FrodoPlayer
    Last Post: 01-13-2005, 06:51 PM
  3. frodoplayer screenshot
    By frodobaggins in forum FrodoPlayer
    Last Post: 08-02-2004, 05:22 PM
  4. v2 screenshot
    By hijinks21 in forum ME Archive
    Last Post: 05-29-2003, 02:29 AM
  5. ScreenShot from MediaEngine 2.0
    By CarComp in forum ME Archive
    Last Post: 05-01-2003, 03:50 PM
