Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: "Map not registered" and "Destinator SDK not for sale" messages *UPDATED*
  1. #41
    Low Bitrate LowLux's Avatar
    Oct 2005
    Qld, Australia
    ok i tried that, its the DestDLL.dll right?
    and it is found in two places, one in the destinator directory, and two in the system32 directory, which ones do i need to replace to get it working? they are both the same version too which confused me, version 1.0.0.1?
    thanks
  2. #42
  3. #43
    Dec 2005
    Igo is a much better utility than destinator
    how about adjusting MM to work with its maps?
    israel desinator 2006 maps work with mm!
  4. #44
    Oct 2006
    Hertfordshire, UK
    OK im a little confused. I have followed the links to buy European maps for MM and they all refer to Destinator for mobiles or PDA's. Is it the PDA maps im interested in? Will they work?
  5. #45
  6. #46
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by midiwall View Post
    They may work in the beta's, but they will NOT work in the (eventual) commercial version of CF.
    Retail Destinator maps will _NOT_ work in commercial CF
    What the ****s this got to do with MapMonkey?
    And that's D6 not D3 anyway.
    bloody tourists.
  7. #47
    May 2006
    Seattleish, WA
    Quote Originally Posted by Enforcer View Post
    My bad... wrong thread.
    Message deleted
    :: Mark
  8. #48
    Newbie thwack's Avatar
    Sep 2005
    Adelaide, SA
    Upgrade Woes
    I recently (yesterday) downloaded and installed the latest version of Map Monkey after very successfully using an earlier version for several months.
    No sooner had I upgraded (had to use full installl to get everything working) and I started having the Not Registered message. I was getting frustrated with not being able to load my maps. Finding this thread solved the problem - restre destdll.dll from my previous installation.
    Is there any way to stop the installer replacing the dll if it already exists. As I think that this is a trap that a lot of people will fall into. Install Destinator then install Map Monkey and have the dll overwritten and then not be able to load the maps they have purchased.
    Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
    Car- 1988 Nissan Patrol 4WD
  9. #49
    Mar 2006
    For the people who are having trouble with the maps "not being registered' try downloading freedrive because it seems to install a version of destdll.dll that works. I did this and now map monkey works fine.
  10. #50
    Mar 2007
    Good,Thanks!
    Where cani find the chinese map?
