Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Latest mapmonkey causing issues to BU-303 users:
  1. #11
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Laidback
    Advanced GPS on, or off?
    Initially On (as it was with all the Map Monkeys), still not sure if it is any different with it OFF.
  2. #12
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Yeah, the latest version has a new "feature" that sabotages the GPS and turns the signal down. You mean you don't like it?
    Seriously, in the transition from BETA 3 to Map Monkey no GPS code was altered. And like I say, it's working beautiful on mine (Adv GPS on, 4800, NMEA)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #13
    Oct 2004
    Netherlands
    also working great here with my bu303 but i have mounted mine inside my spoiler (so semi outside the car) (its plastic so doesn't affect sat reception, always have full signal)
    my destinator map resource down permanently
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by GReeToZ
    inside spoiler?
    hmmmm
    interesting idea
  5. #15
    The land of polar bears and nekkid blonds
    Same here, hot the BU-303 and haven't noticed any differance.
    Depening on cars (lots of rentals) you sometimes have to put it on the roof because the signal is too low inside but that's hardly MapMonkeys fault.
    Usually get around 7-8 satellites, sometimes up to twelve.
    /M
  6. #16
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    I have a BU-303 mounted on the corner of the dash. The only difference I have found since migrating to the full MM is when I'm starting it. Sometimes it tells me I have no lock, so I re-boot MM and all is usually fine. From then on I have 8 to 10 sats and sometimes all 12. I never had to re-boot with beta 3, so perhaps aquisition is a little slower when booting D3 in MM release ?
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  7. #17
    FLAC djmickyg's Avatar
    Feb 2004
    i seem to having trubles too. when i first set up the gps i was locking on 4 sats.. the next time i used it, it wouldnt lock on any. it found a max of 3 but wasnt locking,
  8. #18
    Aug 2003
    Warrington, UK
    The app, along with all the NMEA and SiRF support was designed around and tested on a BU-303! If it doesn't work then your system is having a problem, not Map Monkey
    Try updating drivers, changing USB ports, installing service packs etc... there's nothing more I can do to make it work for you
  9. #19
  10. #20
    Feb 2004
    Quote Originally Posted by Ninja Monkey
    sorry NM wasnt saying it was ur software just saying i have the same issue as all these other people..
    Quote Originally Posted by Enforcer
    http://www.mp3car.com/vbulletin/showthread.php?t=43192
    interesting link.. i think it may have fixed the gps unit..
  1. BU 303 Driver
    By oekundar in forum GPS
    Last Post: 10-04-2005, 11:08 AM
  2. Yet another BU 303 issue
    By G-Han in forum GPS
    Last Post: 10-05-2004, 05:59 AM
