Results 1 to 10 of 20
Thread: Latest mapmonkey causing issues to BU-303 users:
    Dec 2004
    UK
    http://www.digital-car.co.uk/forum/v...646&highlight=
    As being experienced by several users- any idea what could be causing this?
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by organasised
    I read this over there as well.... Has anyone confirmed it doesn't happen with FreeDrive or any other D3-based front end?
    I've got a BU303 and got this with the older version of Map Monkey too... But the BU303 isn't the brightest tool in the box when it comes to aquiring a decent number of satellites.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    I've got a BU-303 and it runs great, the only time I get the "signal too low" message is when I go under a tunnel or a petrol station forecourt etc..
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Dec 2004
    UK
    wheres yours mounted NM?
    Aug 2003
    Warrington, UK
    On my dash
    Aug 2003
    Warwickshire, UK
    The actual message itself comes from D3 though doesn't it... I got it a lot round Birmingham city centre with all the high buildings etc... I just turned off the voice notification so I don't get it loud when the music's blasting.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    After installing the latest MapMonkey I started getting GPS signal too low or the signal is not enough to get a lock, despite having 3 or 4 sats.
    Using mediacar so I keep swapping to the original destinator 2 which is built in. But this only works if I have not started MapMonkey first, otherwise I need to reboot.
    Took the GPSmouse outside the car and the signal is stronger and works OK.
    Have now put a metal tray underneath the GPSmouse and it works better, but still not as it was before Latest MapMonkey.
    So either the latest MapMonkey does something funky or the GPS signal has been turned down for some reason.
    NB will try to use FreeDrive in the next couple of days.
    Aug 2003
    Warwickshire, UK
    seriously there is nothing SW can do to turn the number of sat's down or affect what is received... 3 or 4 sats however isn't a good lock
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It was fine for Route 66, Destinator 2, Destinator 3 and Map Monkey, all the previous beta versions of Map Monkey, it's just since the latest version, whether it be a coincidence or not I don't know.
    PS even with 7 or 8 satellites I still get the weak signal notification.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Enforcer
    Advanced GPS on, or off?
  1. BU 303 Driver
    By oekundar in forum GPS
    Last Post: 10-04-2005, 11:08 AM
  2. Yet another BU 303 issue
    By G-Han in forum GPS
    Last Post: 10-05-2004, 05:59 AM
