Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Importing POI's
  1. #11
    k09
    k09 is offline
    Newbie k09's Avatar
    Feb 2005
    Budapest Hungary
    Quote Originally Posted by dohdoh
    Thanks for your answer. Of course I have all this stuff legal. I'll try that when I'm at home. In case I won't get it, can I ask you again or give me a short instructions. I already know that your example seems very complicated to me due to it seems like I am more nerdy than I thought
    I undertsand how the Destinator POI converter works, but I have problem with English language.
    You can download the Hungarian Destinator upgrade from: http://www.destinator.hu/Destinator_3075.zip
    Unzip the file and write it to a CD. Install the Console program to your PC.
    In the D3_User_Guide.pdf you can see how the POI (Favorites) converter works.
    So, if you want to make a Favorites dat file it takes two step.
    - You have to make a csv file with any text editor (notepad)
    This example shows a traffipax (speed monitor) line: TRAF1,Trafipax,19.04702,47.49015
    The minimum information that you have to give a name, an info, and the coordinata data. You write any necessary lines. Save it to a text file, and rename it from .txt to .csv (e.g. traffipax.txt to traffipax.csv)
    - Use the Destinator Console for translate .csv to .dat file.
    Run the Destinator Console.
    Select Hungary map (Standard Maps
    Push the activated Favorites Importer button
    Give the Input file (.csv) in the popup window
    Push the Convert button
    You can see the made dat file in this directory: DestinatorApps/Installer/Console/IndepIndep/Favorites/
    Sorry my English!
  2. #12
    Feb 2005
    Thanks for your help. Why are you worrying about your English? I just now had a look at your location and saw that you are from Hungary, until now I always thought you were an English man!
    My English isn't perfect either, I'm from Germany but I think it's enough to talk to others, order a pizza or write in this forum
    I will start to try out your hint with the console, hope that works.
    Sorry for I am not really well informed concerning the programming section as I am based on IT, Lan and Security.
    I'll give you some feedback when I finished my job
    EDIT:
    Wow, 65MB... I am a very sad isdn User since 1994 Hope I can manage some friends to get it for me. Thanx to the german telekom for not giving us dsl in our town (5000 citizen, 1000 want to have dsl ordered @ t-online but it seems they don't need that... well, our principal ist dealing with them since last week, hope that will work)
  3. #13
    k09
    k09 is offline
    Newbie k09's Avatar
    Feb 2005
    Budapest Hungary
    It is the smallest map!
  4. #14
    Feb 2005
    Wish I could download via GPS
  1. IGuidance with Streets and Trips' POIs
    By n8scstm in forum GPS
    Last Post: 12-05-2004, 11:47 AM
  2. 11 Million POI's
    By muldrick in forum GPS
    Last Post: 12-01-2004, 08:10 PM
  3. Speed Cameras and POIs
    By DjBac in forum Map Monkey
    Last Post: 11-10-2004, 12:17 PM
  4. Importing Into MapPoint
    By ukchris in forum Software & Software Development
    Last Post: 03-18-2004, 11:41 AM
  5. Alturion 5, how to add poi's for carputer?
    By videodok in forum Software & Software Development
    Last Post: 12-16-2003, 04:27 AM
