Results 1 to 7 of 7
Thread: resolution problems
    Jun 2001
    netherlands
    resolution problems
    i have installed the mapmonkey fulle version, but whatever is state or use in the setup, it wont go full screen.
    tried everything.
    give me some idea's guys
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Post your settings.ini
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jun 2001
    netherlands
    never mind, got it now, the set size and pos at startup was unchecked
    only problem remaining now is that when i embedd in mediacar, it goed full screen over the embedd line in the skin of mediacar ?
    (great work on the application btw, never hurts to give one credit )
    time for the sig:
    Raw Wave
    Jun 2004
    On the beach
    I think the launcher util NM made will fix this, not 100% sure though
    Aug 2003
    Warrington, UK
    If you want it embedded then why are you setting it as fullscreen? You can't have both...
    Jun 2001
    netherlands
    it allways goes fullscreen, either in normal, maximized or fullscreen.
    only difference between them, is that maximized or normal leaves the blue XP border around them.
    just tried the previous beta, and that one does work, it embedds juste under the border of mediacar. (settings set at "normal" )
    time for the sig:
    Aug 2003
    Warrington, UK
    You probably told it to "restore previous sessions settings" and then used fullscreen...so now whenever you open map monkey, whichever window state you choose it's going to restore the width and height of a fullscreen window.
    If you're wanting to embed in mediacar you don't need to set window position on startup, because embedding will override that anyway. The reason the previous beta works is most likely because in mediacar's settings you have the GPS window title set to "Destinator 3" or similar - it now needs to read "Map Monkey -*"
  1. Tutorial: Forcing Custom Resolution in Windows
    By Fuzzball in forum LCD/Display
    Last Post: 12-18-2010, 11:09 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Replies: 0
    Last Post: 01-28-2005, 08:00 PM
  4. Resolution problems with mediacar
    By Slitha in forum MediaCar
    Last Post: 08-23-2004, 06:02 PM
  5. Replies: 0
    Last Post: 06-15-2004, 12:01 AM
