Results 1 to 4 of 4
Thread: Can't Reconnect GPS after Hibernate
    Variable Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Hey NM, thanks so far for all the help provided. The latest problem I have is exactly what the title of this thread says, I can't recconect the GPS after coiming back from hibernation. Offcourse I have the option selected in the configuration menu, however when I turn on the car and it goes back in MM i get the following error
    Error Details
    Error No.: -2147221187
    Description: Could Not open Comm Port!
    Source: Re-Connect_GPS
    Ver 1.1.344
    Help Context 1000440
    Just to let you know I originally had it set up in adv GPS, sirf, com 3, 38400, I then switched it to NMEA, com 3 , 4800 and still get the same error, I have to exit the gps program and re -enter it and then all works well. any ideas? I would greatly appreciate it.
    thanks,
    p.s. also I am using the DENA english skin, however when I press the go home button on the bottom right of the skin nothing happens. I double checked the coordinates in the configuration menu, and they are correct, when I press the check adress button it gives me the correct address. how come nothing happens when i press the go home button in the program?
    Dec 2004
    EDIT: After exploring the skin.ini I just realized the Home icon on the bottom right of the skin is not the Destinate home button, I see there is a DestinateHome option under the Main Menu Bar part of the skin, howeever the settings are set to -1, -1 , -1, -1 , anyway I can add the destinate home button to the skin?
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Destinate Home should be in the "Destinate To..." menu, along with Address, POI, Favorite etc...
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Dec 2004
    Yeah I found the destinate home button exactly there, I was just wondering if it was possible to have a quick access button on the main page skin, so I could simply press that button, rather than have to access a menu. Anyways thanks for getting back to me NM, any ideas about the hibernation problem I described above?
  1. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  2. Replies: 2
    Last Post: 02-07-2005, 01:02 AM
  3. Replies: 3
    Last Post: 12-28-2004, 03:38 PM
  4. Replies: 2
    Last Post: 11-07-2004, 02:46 PM
  5. Which GPS will hibernate?
    By rgardjr in forum GPS
    Last Post: 01-23-2004, 04:48 AM
