Results 1 to 4 of 4
Thread: MM 1.1.3 causing CarPC to Over Heat? :(
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    hey NM... does MM do ALLLLOT of calculations ALLL the time while in route? The reason i ask is because my carpc is freezing about 20-30 minutes into using it (sometimes it takes an hour or 2 of using it)... and i believe i mentioned this to u b4 and im suspecting now that its an overheating issue. Waddya think?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    Check the CPU-usage while using MM then you can see if there is a heavy load on it. It will do calculations all the time but it will depend on your CPU how much of its power it takes.
    Oct 2004
    San Diego, CA
    hmmmm, i think it has something to do with the MM advanced mode... im gonna use MM w/out advanced mode on and ill see if does the same.... im 90% sure its heat related, i just have to find out what exactly is causing it.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    The carpc shouldn't crash in the first place if an app uses a lot of CPU. Run some Prime95 or sisoft sandra for temperature torture by CPU usage
  1. No AC, summer heat...can i still have a carPC?
    By saikano in forum General Hardware Discussion
    Last Post: 07-13-2004, 12:58 PM
