Results 1 to 8 of 8
Thread: please add a Cancel-button to "Add Speed camera" window
    Jul 2004
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Either press "Add Speed Camera" again or press the Home Button
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Somewhat related:
    I click on add camera, then on #, then enter speed... no enter button? Is it just a skin problem? I see a "<--" backspace button, a "." button that clears the speed I typed, and a "-" button that also clears the speed...
    I only have this skin on this comp so if that is the issue Ill get another one...
    thanks!
    São Paulo, Brazil
    scrap that.... I just realized that clicking the speed sign again adds it...
    what is the . and - though?
    thnks!
    Aug 2003
    Warrington, UK
    the . and - are used when you're on the "Manual Destination" screen to enter coordinates, it just uses the same keypad
    Feb 2005
    which sat nav software are you using which allows you to add speed camera locations and does it have noice guidance
    cheers
    Low Bitrate code-'s Avatar
    May 2004
    Haugsund, Norway
    omg, are you blind?!
    São Paulo, Brazil
    Seriously welcome to planet earth newbie... go into the forums, go into the software section, and then READ all the forums....(It shouldnt take long to find the answer)
    -although with the intelligence display u have provided thus far i could very well be wrong!-
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Onscreen keyboard
    By gti in forum Map Monkey
    Last Post: 06-14-2008, 11:00 PM
  3. Add dvd button in skin.ini
    By justme1 in forum FrodoPlayer
    Last Post: 12-27-2004, 09:47 AM
  4. volume button speed
    By Bobby Digital in forum FrodoPlayer
    Last Post: 11-18-2004, 01:51 PM
  5. I want to add a power button on my dash. Which can i use?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 10-25-2004, 04:17 PM
