Results 1 to 3 of 3
Thread: Strange Bug in MM...
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    I reinstalled the OS on my carpc about 10 days ago, then I install RoadRunner and the lastest version of Map Monkey. I uses a Pharos GPS in Advanced GPS mode with Sirf protocol. Everything worked flawlessy for some days but, 2 days ago, when the pc woke up from the hibernation MM said "GPS not found". No matter how many times I tried to reconnect. Of course the GPS was perfectly recognized by WinXP. Then I tried to delete settings.ini, restart MM, configure it for the first time, and it worked. However, if I close and restart MM again, the configure windows pop up again (settings.ini was altready saved correctly!) and then the program won't work anymore. If I delete settings.ini again, I get the same situation.
    What can I do? Reinstall MM? Is this a known bug?
    Thanks in advance,
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    There are some required fields in settings.ini that the configuration won't recreate, you should never delete it.
    I think there may be a problem with your GPS and SiRF mode...try using NMEA and see how you go on
    (You'll probably have to reinstall Map Monkey to fix the settings problem)
    Destinator 3 For PC! -
    Jan 2005
    Milan, Italy
    Sirf is not a problem, since it worked correctly for about a week (before that I used NMEA, instead).
    Tomorrow I'll try reinstalling it.
  1. Bug Tracking List
    By d_sellers1 in forum MMC Bug Tracking
    Last Post: 04-01-2007, 11:02 PM
  2. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  3. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
  4. New Frodo and embedded Destinator 3 / BUG?
    By chuckster in forum Map Monkey
    Last Post: 01-13-2005, 12:16 PM
  5. Odd bug - different song selected
    By Chairboy in forum Media Engine
    Last Post: 09-28-2004, 08:55 PM
