goppieeeeee thanks![]()
Check your mailOriginally Posted by thanatos106
Cool. So, does it work?Originally Posted by thanatos106
I was in my office when I requst the file and today I been working in fabrication......so I will let you Know tonight ......
thanks again
I tried it!!!
It works perfectly about changing MM skins (wonderful!), however, I found some "bugs" (I'm not sure they're really bugs!)...
Consider that I'm using RoadRunner with MM embedded and that this is the first time that I use an external program for gamma setting.
Bugs:
1) When I push the "lighting" button in Road Runner, GammaControl window appears... Isn't it supposed to simply change the skin (assuming that automatic mode is not enabled)? Or have I to make it running before to run RoadRunner?
2) Unfortunately RR crashed, but GammaControl remained active and a million of error pop up windows appeared telling that MM was not foundIs it possible to disable this error notification?
3) I tried to change the brightness in the ini file with a value between 0 and 1, but if I put a value under 0.9, night gamma is like "gamma=1, contrast=1, brightness=1". Pratically, nothing changes!
A request: it is possible to specify the time for the day/night change? Summer is near and day is becoming longer!
Thanks in advance![]()
[QUOTE]A request: it is possible to specify the time for the day/night change? Summer is near and day is becoming longer! [QUOTE]
Tha is what I'm talking about by "automatic change"![]()
1) I don't get the gammacontrol window. I'm guessing that you are missing one of the INI files.Originally Posted by garo
2) Do you know if the errors came from gammacontrol? GC uses the dll file, and I check to see if MM is running and connected before send anything.Code:[Settings] LatDeg=34 LatMin=5 LatSec=24 LatDir=0 LonDeg=118 LonMin=21 LonSec=39 LonDir=0 Day_Gamma=1.09 Day_Contrast=1.04 Day_Brightness=1.06 Night_Gamma=1 Night_Contrast=1 Night_Brightness=0.9 AutoGamma=0 HideOnLoad=1 MinimizeToTray=1
3) I think that 1 is the default value for windows.
GC will automatically know that its the summer, and that the days are longer, the beauty of the GPS coordinates![]()
[QUOTE=thanatos106][QUOTE]A request: it is possible to specify the time for the day/night change? Summer is near and day is becoming longer!It does this by checking your system time and using the GPS coordinates
thanks......... will try it myself later tonight![]()
Hope that it works outOriginally Posted by thanatos106
