Use the SAPI plugin, you can configure it to do exactly that
This is something I miss from the days of using Mappoint with AGPS, it would say the street name I'm supposed to turn on. Ever since I made the move to Routis and Destinator, I have had to look at the screen to know what street to turn onto. I'm using the AT&T Natural Voices speech engine so it doesn't sound so robotic.
Destinator 3 For PC! - http://www.map-monkey.co.uk/
is there a way to figure out how to pause the music long enough until the thing stops talking automatically? say if it starts saying a really long name...
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
Change this line in settings.ini to the number of seconds you want it to mute :
MuteTime=3
Or if you use frodoplayer:
FrodoPauseTime=3
Or you can change it from the setup --> audio mute tab
yes, however, say you have something that goes turn right onto alksjdfoiawjerojialk;jsfdljlsakjasdf rd... even with the longer delay... it may still overlap the music... OR.. if you have something that says turn right on park street. you will be sitting there waiting for music..
The SDK only lets you know when a message is about to start, not how long it is or when it's ended....so the answer is no.Originally Posted by miztahsparklez
Doesn't work with routis or Iguidance though. Only for destinator. Right? Unless I missed something.Originally Posted by Ninja Monkey
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Originally Posted by n8scstm
uhh youre kinda in the map monkey forum.. so i would assume yes.. its for mapmonkey![]()
I know but I meant that mapmonkey only works on destinator and not on routis. I'm not familiar with mapmonkey. I searched but couldnt find a brief explanation of what it is. There should be a sticky explaining what it does. That goes for all software I believe. A brief expalanation followed by a list of features would be nice.Originally Posted by miztahsparklez
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
actually, theres a faq posted up at http://www.mapmonkey.net/ which should answer alot of questions about MM that you may have.
