Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: RELEASE: Map Monkey v1.1.348 (Hotfix)
  1. #21
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    maybe it cleared your config for advanced gps mode? try running config tool and make sure it is there
  2. #22
    Low Bitrate leatherboy's Avatar
    Mar 2005
    Athens, Greece
    Ok, I'll check it but I think It marked as before. Do you know something about frodoplayer?
  3. #23
    Mar 2004
    Stockholm, Sweden
    Quote Originally Posted by Ninja Monkey
    -ETA Distance On the fly
    The ETA has been updated with an experimental new method that allows
    the distance to be calculacted in real time rather than at the
    beginning of each maneuver. ETA's should be more accurate this way.
    This ETA works much better, but is it not possible to get the ETA from Destinator (the one that shows down to the left in the light blue field when routing) ? The internal ETA seems to be more accurate and does not change so much with speed...
  4. #24
    Low Bitrate VehicrossPC's Avatar
    Nov 2004
    Daytona Beach, Fl
    what's wrong with me, I can't find the mml.conf file for mapmonkey
    [------|-] 95% computer... is it ever really done?
    www.vehicross.info for all you VXer's
  5. #25
    Mar 2004
    Stockholm, Sweden
    -Voice Muting
    A new skinnable button has been added that enables you to
    quickly enable and disable the turn-by-turn voice directions.
    An example button has been added to the "Classic" skin.
    Is this command possible to send thru MonkeyTalk/Winsock ??? And if so, what command do I use ?
  6. #26
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Passe
    until the DLL is updated, this is the best you can do:
    MonkeyTalk.Custom("Hotkey_CMD|FE_VOICEPROMPTS")
    which will toggle between on/off, although you won't be able to retrieve the current status
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  7. #27
    Mar 2004
    Stockholm, Sweden
    Thanks, just what I was looking for !
  8. #28
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    How about scroll up/down (the list, not the map) for the DLL?
  9. #29
    Constant Bitrate grum's Avatar
    Feb 2005
    australia, melbourne
    ninja monkey you rule, i love you.
    map monkey is awsome too.
    CarPC Status:
    Hardware: 100%
    Software: 100%
    Case Install: 100%
    Dash Install: 100%
    Car Install: 100%
    crap factor: 100%
    new carpc finished, thinking of way to mount HDD
    and not installed yet.
  10. #30
    Aug 2003
    Warrington, UK
    Quote Originally Posted by 0l33l
    MonkeyTalk.Custom("Hotkey_CMD|FE_SCROLLDIALOG_UP")
    MonkeyTalk.Custom("Hotkey_CMD|FE_SCROLLDIALOG_DOWN ")
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  3. RELEASE: NaviVoice v1.4 - Map Monkey Support!
    By 0l33l in forum PowerVoice
    Last Post: 02-09-2005, 05:11 AM
  4. Replies: 4
    Last Post: 01-31-2005, 07:44 AM
  5. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 06:43 PM
