Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 60
Thread: RELEASE: Map Monkey v1.1.348 (Hotfix)
  1. #31
    Nov 2004
    France
    Hello ninja,
    Is it possible to add a new skinable button for direct acces to "my favoris"
    This feature exist in mediacruiser : one touch give access to the list of elements in a skinnable window
    In your log same action needs :
    Menu - Destination - Favorites - My Favorites -Elements : 5 actions. and aspect is... Beurk! (made by destinator and not mapmonkey).
    This feature allow to plan trajet A ==> B ==> C
    You can save into my favs B and C then it's very easy to calculate :
    current pos to B then current pos to C
    Thanks for your job.
  2. #32
    Newbie Febs's Avatar
    Aug 2004
    Sydney, Australia
    Possibly a silly question, but is it possible to choose a street number when entering a destination?
    On the two MM installs I've used, you're given the option of "Suburb", "Street", "Street" (the 2nd street being for intersections).
    When I was running Destinator by itself before, I could enter a street number, but that option seems to have disappeared after installing MM.
    Hoping someone can help.
    Cheers,
    - Febs.
  3. #33
    Nov 2004
    France
    Quote Originally Posted by Febs
    Cheers,
    - Febs.
    If you choose "Suburb", "Street", in reality you get :
    "Suburb", "Street", "Number"
  4. #34
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Cheers,
    - Febs.
    In map monkey configuration you've changed your default address view to "Intersection". It's under the "Other" tab
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  5. #35
    Variable Bitrate fly_dutchie's Avatar
    Feb 2004
    Amsterdam
    Hi NM,
    MM still doesn't close when clicking the X when embedded in MC. Furthermore, now when it's coming out of hibernation it is not plotting my position although it has satelite lock.
    I tried the launcher fix. That didn't take care of the closing problem. I run in advanced gps mode, plugins enabled.
    Michael
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
  6. #36
    Raw Wave
    Jun 2004
    On the beach
    Works perfectly in RR ..... I'd recommend you switch to RR rather than the now obsolete MediaCar
  7. #37
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Hi all.... is any body else having a problem with RR since the update ? I used to have it embeded now it comes up with about and inch squashed and a great big orange bar where it should show. Tried every thing in the settings of both no joy. Select it to run as an embeded external app and all is fine....
    Strange.
    NM - You at the UK meet this weekend ?
    Terran
  8. #38
    Feb 2004
    Amsterdam
    Quote Originally Posted by UK_MP3Car
    I'm testing that at home the moment.
    It's just driving me crazy that I can't get MM to behave how it should. (not closing properly, then not opening, not coming out of hibernation right...)
    Michael
    edit: Ok, finally ditched Mediacar, thanks Coyote.
    Hello Guino, thanks too. This solved my problems with MM.
    Thanks also NM!
  9. #39
    Nov 2004
    Frankfurt am Main / Germany
    Got a little problem since i installed the hotfix... when is start mm within RR graphics look like on the pic attached. When I start MM normal everything is fine... any idea?
  10. #40
    Nov 2004
    no one any idea??
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  3. RELEASE: NaviVoice v1.4 - Map Monkey Support!
    By 0l33l in forum PowerVoice
    Last Post: 02-09-2005, 05:11 AM
  4. Replies: 4
    Last Post: 01-31-2005, 07:44 AM
  5. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 06:43 PM
