Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: RELEASE: Map Monkey v1.1.348 (Hotfix)
  1. #51
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by LMB__
    is it possible to change the size of the info bar?
    Been a while since I looked at the code but I'm pretty sure the infobar is as high as the INFO_BAR_OFF.jpg image in the skin folder.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #52
    Jan 2005
    Norway, Hedmark
    Quote Originally Posted by Ninja Monkey
    ok thnx!
    but is it possible to remove the add speed camera button from the main bar?
    Mazda 626 2.0i 16v DOCH, 1989
  3. #53
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    is it possible to remove the play, rewind and forward button? just so i have more space for the street name and the ETA field...
    I use CF, and never use these buttons...
    www.superchargedmiata.net - all about roadster lifestyle
  4. #54
    Jan 2005
    Norway, Hedmark
    i think so... (correct me if i am wrong)
    if you go into the skin.ini and find [infobar]
    and then find:
    MediaNext=165,0,79,80
    MediaPrev=0,0,84,80
    MediaPlayPause=85,0,79,80
    and rename to:
    MediaNext=-1,-1,-1,-1
    MediaPrev=-1,-1,-1,-1
    MediaPlayPause=-1,-1,-1,-1
    and then change the images:
    and
    Info_bar_off.jpg to a one colour pic, then they are gone....
  5. #55
    Feb 2006
    Liverpool UK
    setup screen
    hi all
    like wsudu i have installed the update and every time i start mapmonkey i get the setup screen. i have made a new shortcut: C:\DESTIN~1\MAPMON~1\MAPMON~1.EXE (default) and still the same. if i click on the actual file mapmonkey.exe i also get the setup screen. this is stopping the correct launch from frodoplayer because mapmonkey is waiting for the ok button before it displays map. hope you can help.
    garyb
  6. #56
    Newbie Taxi49's Avatar
    Mar 2005
    Australia
    Lightbulb Ninja Monkey
    Ninja Monkey have you ever thought of putting a Donation button on your website. You have contributed so much, I think it's time for some contribution.
    Programing is fun but it's aint easy.
  7. #57
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Taxi49
    Donations
  8. #58
    Constant Bitrate Prefect's Avatar
    May 2005
    Switzerland
    Hi All
    I got myself a new CarPC (CoreDuo System) and currently set up all my apps. With MapMonkey I got two Problems, one is serious:
    1. MapMonkey closes itself constantly after some seconds or minutes. It seems to have something to do with the GPS signal; If I set the GPS port to a unused com-port, MapMonkey stays on the screen without crashing. But as soon as I set the correct GPS port and go into navigation mode (without touching anything else), MapMonkey closes itself after some time. As long as MapMonkey stays open, the position is reported correctly.
    EDIT: Found the new DLL! No Crash till now... So please focus on this: :-)
    2. I normaly use the Map "Alps". Everything is fine, but when I want to enter the name of a city or street, the list of cities or streets only gets updatet till the 3rd or 4th letter. No matter how many letters I type and write the whole name of the city in the field, the list won't jump to the city and highlight it. It just stays on the first city or street that matched the first three letters. On some names the selecting works till the 4th or 5th letter, but most of the time only till the 3rd letter.
    I noticed that this problem seems not to apear in the map "Switzerland" (which I don't want to use...)
    BTW: Did someone find a way to use the new 2006 Destinator maps? MapMonkey refuses to start if I select one of these.
    Thanks a lot!
    Chris
  9. #59
    Mar 2007
    Can i use the Destination6 PPC Map into the mapmonkey?
  10. #60
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by damyrice View Post
    Afraid Not
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  3. RELEASE: NaviVoice v1.4 - Map Monkey Support!
    By 0l33l in forum PowerVoice
    Last Post: 02-09-2005, 05:11 AM
  4. Replies: 4
    Last Post: 01-31-2005, 07:44 AM
  5. Map Monkey final - release data?
    By alanp in forum Map Monkey
    Last Post: 01-27-2005, 06:43 PM
