Code:
[v1.1.348 Official Hotfix]
*New Features*
-Voice Muting
A new skinnable button has been added that enables you to
quickly enable and disable the turn-by-turn voice directions.
An example button has been added to the "Classic" skin.
-Optional Alternative OSK Method
In the skin.ini you can now specify to use an alternative
method for sending the key. This will help in cases where
certain foreign keys are sent incorrectly (e.g. í)
-Automatic Reconnect of GPS
If automatic reconnection is enabled, as well as reconnecting
when returning from hibernate, Map Monkey will also attempt
to automatically reconnect the GPS when gaining a signal
after previously losing it.
-Optional Height Offset of Mapping Window
You can now specify a "HeightOffset" value in the settings file
to increase / decrease the height of the mapping window. This can
be used to hide the default Destinator status window.
-SDK Hotkey Command
A new SDK command has been added to allow developers to call one
of the commands used in the Hotkeys.ini file. This enables extra
functions such as scrolling dialogs and opening / closing
menus to become available.
This must be called using the "Custom" method.
e.g.
MonkeyTalk.Custom("Hotkey_CMD|FE_EXIT")
*Changes / Fixes*
-New Hotkeys
Hotkeys have been added to do the following :
-Toggle between map views
-Activate 2D View
-Activate 3D View
-Activate Birds Eye View
-Toggle Turn-By-Turn Directions
-ETA Distance On the fly
The ETA has been updated with an experimental new method that allows
the distance to be calculacted in real time rather than at the
beginning of each maneuver. ETA's should be more accurate this way.
-Reconnecting after hibernate
A time delay has been introduced before Map Monkey will reconnect the
GPS device after returning from hibernate. This may help with
problems in connecting the COM port before windows has
re-detected it.
-Speed Camera Notification
You can now click an empty space in the speed camera notification box
to hide it
Download here [594KB]
