Results 1 to 5 of 5
Thread: Not Running
    Mar 2005
    Not Running
    I try to use MapMonkey in my Visualbasic6.0sp6 project, but the property (IsMapMonkeyRunning) is always False.
    I try enclosed example and the result is the same.
    Where is the mistake??
    Luca
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    You need to enable "Plugin Support" in map monkey configuration
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Mar 2005
    Ok Tanks, perfect.
    I use mapMonkey embeded in a picturebox, before the command (mTalk.EmbedMapMonkey picGps.hwnd, False), i launch (Call Shell("C:\DestinatorApps\Map Monkey\MapMonkey.exe", vbMinimizedNoFocus)) but not alwais work correcly.
    Are there another system??
    Tanks
    Luca
    Aug 2003
    Warrington, UK
    Why doesn't that work?
    Mar 2005
    I dont' Know because doesn't work, but i isMapmonkyRunning as False, but i I Manually Before launch Mapmonkey.exe, Work Corrrectly
    my code is:
    Set mTalk = New MonkeyMessenger
    ReadSkinGps
    If mTalk.IsMapMonkeyRunning Then
    mTalk.connected = True
    Else
    MsgBoxCustom "GPS Non Attivabile", vbCritical, , 5000
    End If
    If mTalk.connected Then
    Timer1.Enabled = True
    Else
    Timer1.Enabled = False
    End If
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  2. Replies: 23
    Last Post: 03-21-2005, 04:45 AM
  3. Replies: 2
    Last Post: 12-17-2004, 02:27 PM
  4. Running Two Computers?
    By dapilot in forum Power Supplies
    Last Post: 04-15-2004, 09:14 AM
  5. Replies: 9
    Last Post: 11-01-2002, 12:21 PM
