probably a stupid question but what is a HUD display?![]()
Well guys i know how I will do this and have source code in VB for it and it will work great
I just need to know how many turn signals would i have to display on the HUD i'm gonna build?
there's left right stright and roundabout what else would i need?
I also need to know if it's possible to know if the next turn is a left right or stright turn?
I've got the planning done just havent looked into MM for getting the values out yet.
So can someone give me an answer?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
My guess would be a Head Unit Display displayOriginally Posted by aguila
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
Maybe Head Up DisplayOriginally Posted by mox
Possible Turn Types:
"No Solution"
"Straight"
"Turn Left"
"Turn Right"
"U Turn"
"Roundabout U Turn"
"Roundabout Left"
"Roundabout Right"
"Roundabout Straight"
"Keep Left"
"Keep Right"
"Keep Straight"
"Exit to Roundabout"
"Arrive at Destination"
"Unknown"
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Well here is what a HUD display looks like:
It reflects light from a display in or ontop of the dash so when you look through the windshield you will see it like it's floating in air.
In response to 0l33l
There is no screen shot it's just a VB app which sends data to the parallel port which in turn turns 8 led's on and off.
I have seen some delphi code around for it so i can search for that if you like.
But it's just a very simple LED on/off program.
The LED's are inside a small strip which has a plastic window infront of each LED so this window has the Arrorw on it so when it lights up you will see the reflection
Does this make sense? the whole thing only cost $10 max for the componets as it's only 8 LED's 8 Resistors and some wires and a DB25 connector
The box for the turn signals on the other hand i don't know how much it will cost i will have to work it out.
Now i have 2 locations either on the dash so i see it at the bottom of the windshield or behind the rearview mirror.
Cause my car windshield is sloped quite a bit i would see the top of the windshield easier and also it has that blue crap at the top of the windshield for protection your eyesthis should give me a better reflection but i'll have to try it out first
Any questions? it's a very basic circuit![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Wonder what would be a nice sign for the "No Solution" type of turn? Maybe a big "Hit the damm breaks" sign? lol
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
@NiN^_^NiN
If functional that would be a great gadget!! Think I might experiment a bit with the idea![]()
BraveCar 2.5
