Why are you running 1.1.2?
Is it possible to increase the delay of the frontend when talking to the client for the first tiem on startup? As due to the slowness of the hard drive and the large size of the Australia map it takes longer than the specified "1,2,3, Is the SDK installed properly?" timeout. If the Florence map is loaded at startup the client/frontend load fine, then I can switch to the Australia map without a problem. I am running Windows ME. Map Monkey v 1.1.2.
Fox Mulder
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
Destinator 3 For PC! - http://www.map-monkey.co.uk/
v1.1.3 requires XP doesn't it?
Oh and I don't have XP due to the lack of space on the hard drive.
Fox Mulder
2004 Toyota MR2
I wasn't sure that 1.1.2 worked on ME! If it does then I don't see why 3 wouldn't, give it a try![]()
Gave it a try, it comes up with that error in the installation saying "Map Monkey cannot be installed on Win9x/ME" Maybe it has something to do with the installshield where even though the program can work on ME, it puts win 9x and win ME in the same category.
Fox Mulder
2004 Toyota MR2
