I used key exe and the numbers are the same!!!!
With this skin ini is working???
For OSK to work in greek you must alter the skin.ini file
under the OSK heading.
You must use the key.exe program to find the appropriate key positions for the greek aplhabet.
See the skin.ini attached file
Just installed MM on a swedish Win XP home ed. and i get the same problem.
Ok I got my GPS receiver the other day and I didn't have the time to dig into the problem anymore. I wanted to get the thing up and running. So I reinstalled Win XP pro SP2 SWE. And everything worked like a charm![]()
