Results 1 to 4 of 4
Thread: Turn off vertical scrollbar?
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Is there a way to turn of the zoom in/out scroll bar? I can't see any settings ofr it except the thumbnails in the Destinator.bmp. Can I make these 1x1 pixel images and reduce it that way?
    I have a scrollbar controlled by RR and it allows me to be a bit clever when scrolling
    Thanks!
    BTW, there seems to be a bug when turning off the bottom status bar, if you cycle between OSK and Naviagate to Fav. a few times it appears and disappears. I have not had time to figure out the flaw pattern.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    you could edit C:\DestinatorApps\Destinator\Common\Interface\Visu al\All\destinator.ini
    ::P,SLIDER,100,34,48,90,1,1
    ::P,BAR_SLIDER,142,48,48,48,0,0
    ::P,ZOOM_IN,1,47,48,48,0,0
    ::P,ZOOM_OUT,50,47,48,48,0,0
    the above tells D3 what zoom to use. You could just set this to 0 pixels wide
    think if you just change the third and fourth value to 0 you should be fine.. I aint tried this so dont blame me if it dont work ;-p
    Jan 2005
    Spain
    Cheers CDRSKULL, worked a treat.
    Now all I need to do is improve my graphics skills! I'm artistically challenged!
    Low Bitrate studly_steve007's Avatar
    Mar 2005
    Barnsley / UK
    Quote Originally Posted by CdRsKuLL
    Just a quote note for anyone trying this, I found if I changed skin in MM config after zero'ing the zoom then it reset these values back to display the zoom. So if you change the skin you have to re-zero them.
  1. Remote turn on lead? (Super Noob)
    By Cosine in forum Power Supplies
    Last Post: 09-02-2004, 04:55 PM
  2. How should I turn on my invertor
    By Slitha in forum Power Supplies
    Last Post: 08-22-2004, 10:12 PM
  3. Navigator Turn by Turn V2
    By CRCinAU in forum GPS
    Last Post: 08-08-2004, 05:49 PM
  4. Replies: 4
    Last Post: 03-25-2004, 05:53 AM
  5. Replies: 0
    Last Post: 07-22-2002, 11:45 PM
