Results 1 to 6 of 6
Thread: GPS not found
    Apr 2005
    Israel
    GPS not found
    Hi All,
    New to the forum...my first thread!!
    I have installed map monkey and have local maps of destinator. So far so good.
    However, my Deluo GPS (connected to the laptop via serial>usb) is not found. The issue is that i have set it correclty and can see on the gps setting screen my lat, lon, time etc', when i press the find gps it founds it and then nothing happens.
    In the main screen i get GPS not found and no information on the map
    Any ideas?
    Thanks alot,
    Zohar
    Apr 2005
    Israel
    Got it
    Ok went for a night drive to test all the options.
    Now it is working with the deluo gps connected to the serial. However, when connect to the usb through the adaptor (provided by deluo) it is not.
    It is set to the correct virtual port (4) but not found.
    The biggest bummer with the deluo which I found is that it takes ages to acquire position, I can get to most of my destinations before handů
    Any clue to both issues?
    Thnx, Zohar
    Super Moderator xBrady's Avatar
    USA
    Have you tried setting it up using the advanced GPS options.
    Installed.
    -GPSSecure- - GPS Tracking
    Apr 2005
    Israel
    Hi,
    you mean in the gps setting screenin map monkey; port, rate etc?
    If this is what you mean then yes.
    If there is any other advnaced then I am not aware of it.
    Aug 2004
    go to start menu, programs, map monkey, and click map monkey configuration.
    click the advanced gps tab, set it to 'on', enter your port information and click ok. MM will boot up and all should be ok.
    Apr 2005
    Israel
    Thanks Viniser,
    I will try it.
    Zohar
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 02:57 PM
  2. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 02:51 PM
  3. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
  4. Real GPS Software for Linux FOUND
    By Mxyzpltk in forum GPS
    Last Post: 10-11-2003, 08:58 AM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 02:26 AM
