Results 11 to 20 of 22
Thread: Maneuver Distancein MonkeyTalk
  1. #11
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    NM, any news!?
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
  2. #12
    Raw Wave
    Jun 2004
    On the beach
    NM - is there a command to pull all the maneuvers from a route list as a string or similar???
  3. #13
    Nov 2004
    St Louis
    Quote Originally Posted by UK_MP3Car
    I an working on a similiar change to the Mac_V2 day/night skin for RR. The Main menu has many redundent labels so I decided to try to pull the next manuever, distance, and roadname as labels and replace the coords and speed. Tried the "MM;ManeuverUpdate" command but that is "unrecognized command" when the skin is running.
    NM are there label commands I can use to get those three as text/numbers?
    UK_MP3Car: Please share with the rest of us how you got the turn symbols working , I'd love to put those on my skins.
    Thanx
    Giz
  4. #14
    Apr 2005
    The Netherlands
    Quote Originally Posted by GizmoQ
    Thanx
    Giz
    Do you mean 307SW_NLD?! I made some changes to the VB code of RR. The turn sumbol is a new indicator I created in RR that you can add to your skin file. If you want I can take the last release of RR and re-add the code (will only take me a few minutes) and send you the RR.exe you with a sample skin file. You will also need some jpg with the arrows. You can either make your one of I can send you sample (white and orange)
  5. #15
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 307SW_NLD
    Same problem here. I'm writing some custom code in RR to get some additional information in a label in RR (Distance to next maneuver). The maneuverDistance() method returns the value of the maneuverID that you supplied in the method.
    Using the maneuver types I'm also adding pictures in my audioplayer screen and want to add the distance to the maneuver as a nice big label. Hopefully Guino will add the code to the base version of RR (said he would)
    Hey man, the problem I have with your code is: I never got the IMAGES to try it out/tweak it a little... The code has been sitting on my desktop for awhile now..
    EDIT: nevermind.. found the images in another machine I downloaded it at..
    Ride Runner RR's Myspace
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If the whole issue is to make a composite command based on the response from a previous command, I can probably add that myself.. I'll take a look at it..
  7. #17
    Nov 2004
    St Louis
    SEND IT ALL!!!!!
    sorry 'bout the wrong name.
    I'll PM you my email address.
  8. #18
    Apr 2005
    The Netherlands
    SEND IT ALL!!!!!
    And!? Did it work? Can you show us the skin with the indicator?
  9. #19
    Apr 2005
    The Netherlands
    Quote Originally Posted by guino
    I have been looking into the commands that I can use either by MonkeyTalk or the socket but I can't find another way to find out the distance to the next maneuver other than the way I was using. The response from the function is the same as the input (like you would do when you implement a new function and return the input values when the function is not yet finished but you want to compile the code)
  10. #20
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Yeah I think that's a bug...It's on my list of things to fix when i have some time
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  1. Bad performance with retrieving Monkeytalk info
    By xBrady in forum Map Monkey
    Last Post: 05-20-2005, 04:07 AM
  2. Replies: 10
    Last Post: 03-30-2005, 02:00 PM
  3. Help with MonkeyTalk and Delphi
    By Passe in forum Map Monkey
    Last Post: 03-13-2005, 03:40 PM
  4. MonkeyTalk SDK - swap map question
    By Onagrote in forum Map Monkey
    Last Post: 02-01-2005, 02:02 PM
  5. Change font in drop-down turn-by-turn menu?
    By maronoff in forum Map Monkey
    Last Post: 01-19-2005, 10:08 AM
