Results 1 to 10 of 16
Thread: RR Menu to emulate MM Menu button
    Nov 2004
    St Louis
    NM,
    In my attempt to gain full screen height for the MM display, I have created a Road Runner menu to emulate the MM menu button. Problem is, I can't find some of the commands in the MM SDK. From what I can tell the following RR commands work:
    d3_main_menu_empty.jpg,d3_main_menu_off.jpg,d3_mai n_menu_on.jpg,d3_main_menu_down.jpg
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,71,173,66,76,"EXIT||MM;LOCATE",locate
    B,5,173,66,76,"EXIT||MM;CancelRoute","cancel route"
    B,137,103,68,70,"EXIT||MM;PlayRecord","play/record"
    B,70,102,67,71,"EXIT||MM;Manoeuvres","roads"
    B02,70,25,66,77,"EXIT||MM;Show_GPS_Status","gps status"
    B03,136,26,69,77,"EXIT||MM;Settings","Settings"
    B04,5,103,65,70,"EXIT||MM;ShowRoute",show route
    B05,187,-1,23,25,"CANCEL","Cancel"
    END
    These don't:
    B,5,25,65,76,"EXIT||MM;???????????????","plan route"
    B,137,173,67,76,"EXIT||MM;QUIT","close map monkey"
    The first is the main menu item "plan route" which opens another menu with the different routing options, I think you call it the "Route To" menu. I need a command to call this second menu from RR. The next line I'm having trouble with is the exit or quit command. As written above, MM does nothing, maybe a brief blink when switching back from the RR menu, but it doesn't close MM.
    Another command that I have moved to the RR skin that doesn't work is this one:
    B31,159,66,59,54,"MM;Home","go home"
    I thought this was the command for MM to automatically create a route to the "home" location loaded in the config menu using lat/lon. As above, executing this command yields no response from MM.
    Lastly, I was wondering if you could create two new commands I've seen more and more in Road runner skins:
    Day/night toggle
    2D/3D/Birdseye view toggle
    I've seen this on two other skins and neither has it working. If I had played with their skins before developing my own I would not have included it. They both tried to accomplish it with hotkey commands, but RR doesnt allow TCP and hotkey (one or the other, but not both). Without these toggles, my two toggle buttons will have to be replaced with 5 individual command buttons and I just don't have the real estate available. The following is a mock-up of what my destinator screen looks like:
    So I would like to formally request toggle commands for views and day/night.
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    Here's what I have on the ones you want:
    Day Night Toggle:
    "MM;Hotkey_CMD|FE_COLORMODE_TOGGLE"
    View Mode (2D/3D/BirdCrap View)
    "MM;Hotkey_CMD|FE_VIEWMODE_TOGGLE"
    Plan Route:
    "MM;Hotkey_CMD|FE_MENU_ITEM_ROUTETO"
    Quit:
    "MM;Hotkey_CMD|FE_QUIT"
    This brings you to the Map Screen if you have an open dialog
    "MM;Home"
    I suggest you check the HOTKEYS.ini file in MM. This has all the API commands that I use in RR, just prefix them like I have above.
    PM me, and I can send you my customised SkinEditor Object file with all the MM commands for RR.
    Nov 2004
    St Louis
    Quote Originally Posted by ruairi
    Day Night Toggle:
    Plan Route:
    Quit:
    "MM;Home"
    Hotkey commands copied into my skin file, but still no go. What do I need to do to turn them on?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Latest version 1.1.348 or whatever it is... if you have a slighlty older version it wont work... that is what I was ding wrong... missed 1 patch by 1 day and was breaking my head cause it didnt work... are u sure u have the latest?
    Jan 2005
    Spain
    Also, apart from 1.1.348, make sure you have plugins enables and port 9913 in the settings.ini of MM. Check settings.ini has something like:
    [Plugins]
    //Allow custom apps to interact with the frontend?
    Enabled=Yes
    ListenPort=9913
    Nov 2004
    St Louis
    Quote Originally Posted by RoyN
    Got it working now. Thanks everyone.
    Now, if I can just figure out how to allow/keep the video sound to keep playing until I start another audio function ....
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by GizmoQ
    The only way to play audio of videos while not in the video screen is while either the Mixer or Video Browser -- OR if you add the videos in the AUDIO browser, in which case the video screen MAY popup, but you can easily click on RR's screen and then it will be on the background...
    Ride Runner RR's Myspace
    Nov 2004
    St Louis
    Hey Ruairi,
    Was playing around with the MM SDK this weekend and finally figured out single key command to route home:
    "MM;RouteTo|Longitude|Latitude"
    This was the only command left that I hadn't figured out. Thanx again for all your help.
    Jul 2006
    Are there separate commands available in MM to switch DAY or NIGHT modes from within RR, rather than a toggle?
    I see there is a MENU_BUTTON_DAY and MENU_BUTTON_NIGHT, but I cant seem to get these to work in the RR skin I'm mucking around with.
    Variable Bitrate M^ck^y's Avatar
    Aug 2004
    Melbourne
    Does anyone know if there is a command to reconnect theh gps?
  1. Creating RR Skin For MM
    By studly_steve007 in forum Map Monkey
    Last Post: 04-14-2005, 02:20 PM
  2. Replies: 2
    Last Post: 04-04-2005, 04:45 PM
  3. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
  4. my menu button doesn't work on my skin
    By gambit32 in forum FrodoPlayer
    Last Post: 10-02-2004, 08:53 PM
  5. How to setup gps button in menu
    By Tyrael in forum Media Engine
    Last Post: 02-25-2004, 03:53 PM
