Results 1 to 8 of 8
Thread: Acquiring Sattelites problem in Mapmonkey
    Jan 2005
    I just installed Mapmonkey on my car PC. The GPS was found in Mapmonkey (COM1 38400 NMEA), but it doesnt function because it is "acquiring satellites" constantly
    What did I wrong?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Well, it takes a WHILE to acquire sattelites for the first time.
    Jan 2005
    I tried it for about 10 minutes,any idea how long it takes first time?
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Macklion
    Seems a bit much. Put the receiver on the roof. Also, I'd try to change the bitrate to 4800.
    Jan 2005
    My GPS a Leadtek with TMC is found as COM1 NMEA 38400, other mode is not possible, anyone a solution?
    May 2005
    im having the same issue i need a way to test this usb gps but i cant seem to find anything thats simple enough for me to test it with in map monkey it sits saying aqquiring satalights
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    After having my carputer out of action for a few months...it took around 2 days before my bu-303 could get over 4 satellites. After that it takes around 20-30 seconds.
    Strange but true!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    May 2005
    Quite odd indeed, this happend to me, i left it on over night and it then found a sat! I had also installed destinator front end and it worked in that, so i thought id try map monkey again and it worked! I not sure whats going on there but it seems to work now! I basically installed both and its now working!
    Cant wait to for them to send me the SDK so i can get out in the car and test it properly!
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  3. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 09:27 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
