Results 1 to 4 of 4
Thread: Map Monkey SDK not working
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    I was playing around with embedding Map Monkey into an application. I couldn't get it to find map monkey. The problem is when I run the project1.exe file in the demo sdk directories, it can't find map monkey running either (and yes, I have map monkey running when I try).
    Any ideas guys?
    Raw Wave
    Jun 2004
    On the beach
    Have you changed the settings.ini file to allow remote connections??
    Jan 2005
    Quote Originally Posted by UK_MP3Car
    Thanks! That was it. The demo works, now onto getting it in my .NET app.
    Anyone here embedded Map Monkey into a .NET application?
    Jan 2005
    Okay, got it working.
    For those wanting to embed map monkey into a .NET here is the vb.net (visual Basic.net) code (add the MonkeyTalk.dll to your references as a COM component of course).
    Oh, I put a Panel on my form called PanelGPS, the application embeds to that panel. I'll have more stuff for this in a few weeks as this grows, I'll most likely write a vb.net class around the MonkeyTalk.dll.
    My plan? To build a Satellite Radio/MP3/GPS application for use in my car.
    Code:
    Dim MapMonkey As New MonkeyTalk.MonkeyMessenger
        Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
            If Not MapMonkey.IsMapMonkeyRunning() Then
                Shell("C:\DestinatorApps\Map Monkey\MapMonkey.exe", AppWinStyle.Hide, False)
                Dim I As Integer
                For I = 0 To 100
                    Threading.Thread.Sleep(10)
                    Application.DoEvents()
                Next I
            End If
            If MapMonkey.IsMapMonkeyRunning Then
                MapMonkey.Connected = True
                Dim M As Integer = Me.PanelGPS.Handle.ToInt32
                Dim S = MapMonkey.EmbedMapMonkey(M, False)
                MessageBox.Show(S)
            Else
                MessageBox.Show("Map Monkey is not running.")
            End If
        End Sub
  1. Replies: 36
    Last Post: 12-13-2005, 08:38 AM
  2. map monkey doesent move
    By sportive in forum Map Monkey
    Last Post: 05-09-2005, 01:19 PM
  3. Map Monkey + TMC
    By Mcnovy in forum Map Monkey
    Last Post: 03-24-2005, 04:51 PM
  4. Replies: 23
    Last Post: 03-21-2005, 04:45 AM
  5. Replies: 4
    Last Post: 02-26-2004, 10:52 AM
