Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Wainting on SDK
  1. #11
    Apr 2005
    I had my DLL within 2hours
  2. #12
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    What is the "DestDLL_08_05.zip" ?
    I only got a link to 3.0.75_97_COM_API.zip from Destinator after purcase of the SDK.
    Thanks!
  3. #13
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Quote Originally Posted by Jeep
    Thanks!
    The destdll.dll file that comes with the sdk won't read maps > 3 Megs in size. However, the destdll_08_05.zip contains a destdll.dll which allows you to use maps > 3 megs in size which is suppose to expire in august of this year. However, I changed my date on my computer to next year and the file worked fine, so not sure how it's supose to expire.
  4. #14
    May 2005
    Hi Guys,
    Just received my copy of the SDK file DestDLL_08_05.zip from Rafiq, I am just discussing the ongoing situation with him now over the expirey status and future strategy etc.Seems responsive right now, I will summarise the conversation when I have some conclusions...
    Looking forward to getting map monkey working properly tonight when I get home.
  5. #15
    May 2005
    Exclamation
    Hi all,
    below is the guts of an email conversation I have had with Rafiq on the SDk situation.
    Although it is not conclusive, it does give me some faith that thing will shae out in due course.
    Read from the bottom up.
    Hi Rafiq,
    I will stop disturbing you now!
    I appreciate your time, and have faith that some form of solution will be available to licensed SDK users when this SDK DLL expires.
    Thans again.
    Rafiq Kassam
    > Hello,
    > I am not sure what you mean by 'gap' solution however this is for developers who
    > want to test their application in their local area. That's what this file is
    > for. Just to give them some flexibility to develop and test at this time. If a
    > PC version does become available this doesn't mean that you will receive a copy
    > of it. When using a third party application you need two items. A) a licensed
    > copy of Destinator and maps B) a copy of the SDK. Hope this helps explain.
    > Thanks
    > Rafiq
    > -----Original Message-----
    > From: anthony>
    <snip>
    > Subject: RE: DestDLL_08_05.zip
    > Thanks again Rafiq,
    > So if I understand you correctly, then the .DLL with an expirey is a stop gap
    > solution, and that when the official PC version is available, then those who
    > have purchased an SDK previously will have access to it?
    > Do you mind if I summarise this conversation on the development forum to reduce
    > the panic that seems to surround this subject?
    > Rafiq <snip>
    > wrote :
    > > Hello,
    > > Yes the SDK is for development on both PPC and PC. Once a PC version
    > becomes
    > > available this should not be an issue. Much information regarding this is
    > not
    > > available at this time. If you want to check in with me after a few weeks I
    > can
    > > update you if I have any new details.
    > > Hope this helps.
    > > Thanks
    > > Rafiq
    > > From: anthony <SNIP>
    > > Hi Rafiq,
    > > Thankyou for your prompt reply.
    > > I suspect we are in a bit of a grey area here.
    > > I have purchased a full copy of the UK Destinator 3 software which currently
    > is
    > > targeted at the Handheld PC.
    > > The use of this SDK allows that data to be accessed by a package that is
    > PC
    > > based.
    > > Is this against the spirit of the licensing, or are we just stuck in a grey
    > area
    > > due to the delay in a PC based version of Destinator 3?
    > > Thanks again for discussing this.
    > > Rafiq <snip>
    > > wrote :
    > > > This file is just to allow developers to have some flexibility with
    > their
    > > > testing. If you are using another application and our SDK you will need
    > to
    > > > purchase a full version licensed copy of Destinator. Hope this helps.
    > > > Thanks
    > > > Rafiq
    > > > From: anthony<nip>
    > > > Hi Rafiq,
    > > > Thankyou for your reply.
    > > > No doubt you are aware this expirey date is causing some consternation
    > > amongst
    > > > the developers in the car pc world.
    > > > What is the ongoing strategy for development against the SDK past the
    > > expirey
    > > > date?
    > > > <snip>
    > > > wrote :
    > > > > Hello,
    > > > > I have attached the file. This file will enable you to use full sized
    > > maps
    > > > > during your development. It allows developers to test their
    > applications
    > > > in
    > > > > their local area. It does have an expiry date set.
    > > > > Thank you
    > > > > Rafiq
    > > > > From: anthony
    <sNip>
    > > > > Subject: DestDLL_08_05.zip
    > > > > Hi There,
    > > > > As previously emailed, I have purchased the SDK for your product, and
    > > now
    > > > > require the file DestDLL_08_05.zip
    > > > > The original purchase was made against
    > > > > <snip>
    > > > > I cannot proceed with out this file.
    > > > > Please can you forward it ASAP.
    > > > > Thanks in Advance
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by firmware
    > Hello,
    > Thanks
    > Rafiq
    The last email basically leaves it as clear as mud. It looks like they are giving developers the tools to create an application, but not a way for it to be used.
    We will only be able to use Map Monkey/Freedrive or the such IF they release a PC version.
    Total crap.
  7. #17
    Jan 2005
    Okay, if I set my time and date to 2006 on my computer the DLL still works, but does the GPS data also include time and date information? If so, they might be using this information to expire the DLL
  8. #18
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by fromplanetbob
    If that's the case I'll simply spoof the time and date before the data gets to the destinator interface. It's not like anything in Map Monkey uses the GPS time.
    Either way, people who have paid $50 are still going to have a working version after august. Poweloc/HSTC aren't getting away with that stunt!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  9. #19
    Low Bitrate ALonDonThinG's Avatar
    Aug 2004
    London
    Hmm, i originally bought Destinator3 because it said on THEIR website it WAS for PC\Notebook, lol there is even a picture of a laptop on the box!!
    In my book i was robbed by them, they wouldnt even reply to my emails, in which i had screens of there "webvert" proving they misinformed me, all this time later and they still havnt made a real PC version, but they still taking our money selling us SDK,s that may or may not work in the future.
    Anything short of a good working pc product given free to all the people who have been blatently ripped off by them wont redeem them in my eyes .
    As you can tell im still p***ed at them , but only half as much as i would be if it wasnt for NM
    Epia SP1300\512 ddr\40g 3.5" hd\cartft-touchscreen\GPS-destinator \M1-ATX\Audigy1\Linksys-wirelessB\anafekkingbigamptojblspkrs.
  1. Replies: 19
    Last Post: 08-30-2006, 07:27 AM
  2. iGuidance SDK
    By Quattro in forum GPS
    Last Post: 06-23-2006, 08:37 AM
  3. Replies: 9
    Last Post: 03-31-2005, 03:40 AM
  4. Destinator 3 SDK features working
    By loscooby in forum GPS
    Last Post: 09-21-2004, 01:46 AM
