Results 1 to 5 of 5
Thread: Problems with new install
    Feb 2005
    Angry Problems with new install
    Help me please. Iafter a few months I have finally installed my carputer into the vehicle. All was ok until I drove off, and then noticed the sat nav was not updating the screen. I have a Globalsat 303 receiver which is getting sat lock on 4 or 5 sats, butv map monkey is reporting 0 sats. If I close down and re open map monkeyI get my current location, but does not update when I drive away. Any suggestions please. I have searched the forum, but not found the same problem. I posted earlier today but I think it was in the wrong section...Apologies for that. Many thanks in advance.
    Apr 2005
    Quote Originally Posted by galant
    And you ahve tried to change SIRF/NMEA ? Also, where is your receiver located ? It should be placed so that its not blocked by roof or anything.
    Feb 2005
    Wink Problem Solved
    Thanks for your reply. I traced the problem to set up. For some reason the com port settings had changed to Com 4, where as the GPS is on Com 3.
    Thanks for your help.
    Low Bitrate M11VNY's Avatar
    Aug 2004
    Leicester & Reading, UK
    The only time when the comm port seems to change for the gps reciever is when you unplug it from one usb to another, I had this problem when I kept swapping them around as only had the two usb ports on motherboard.
    Its down!!!! Sold the Golf so took it out, it's still alive but not installed.
    Progress [-----------] 0%
    Who the Daddy Iz!
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    don't crosspost
    Read the rules
  1. Software install problems
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 05-01-2005, 03:40 PM
  2. problems with M10000 and WD 80GB HD
    By wyckyd in forum General Hardware Discussion
    Last Post: 08-05-2004, 02:33 PM
  3. DLink DSB-R100 Install Problems
    By paiged in forum General Hardware Discussion
    Last Post: 07-20-2004, 06:56 PM
  4. Harddrive problems....bios?? or just OE
    By stinkynathan in forum General Hardware Discussion
    Last Post: 11-18-2002, 11:15 AM
