Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Voice prompt volume??
  1. #11
    May 2005
    Herts, UK
    There is a setting in the ini file which stops the volume change - ManeuverRepeatTimeout=15 needs to be changed can't remember what though - a search should reveal that one. To get the overall volume of all voice prompts lower in relation to the music volume you will need to create a new set of wav file files which have had some attenuation applied. I have found that a 4dB reduction, a bit of bass cut and a bit of treble cut applied to the existing uk voices works just fine. I used a freeware audio editor to apply the changes to the existing wavs.
  2. #12
    May 2005
    Quote Originally Posted by Pentode
    I've changed the setting in the settings.ini file, and this seems to work Thanks!
    Could you maybe send me a zipfile with your edited voices? Thanks in advance. (meelobee[a]hotmail.com)
  3. #13
    May 2005
    Herts, UK
    I'll mail it in the next day or two - I need to get in the car and copy them back over to here!
  4. #14
    May 2005
    Would be much appriciated (sp?)
  5. #15
    May 2005
    Quote Originally Posted by Meelobee
    Looks like I cheered too early. It still has the wrong volume at times, it looks like the volume mute goes back to 100% too early, so the last words of some sentences are spoken way too loud. (which is killing my tweeters! )
    Anyone else know of something to solve this?!
  6. #16
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    The volume mute uses the same timeout settings as the Line-Mute setting, which I think is defaulted to 4 seconds.
    In configuration, under "Audio Mute", change 'Resume After x Seconds' to a higher value
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  7. #17
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by thanatos106
    Mine doesn't work at all also it doesn't pause frodo.
    Thanatos.
    Same here, even updated windows media player to the bigger more bloated cpu intensive version, not no better...........
    (except my xvids are now more jumpy)
    Why in the mapmonkey / frodo ini files it keeps saying winampetc, when mp3's are playing it uses media player?
  1. Destinator Voice prompt on the second sound card
    By siukalo in forum Map Monkey
    Last Post: 05-13-2005, 10:11 AM
  2. how do I alter the voice nav volume
    By sygad in forum Map Monkey
    Last Post: 01-23-2005, 11:44 AM
  3. How to change voice volume within Frodoplayer?
    By vintageb3 in forum FrodoPlayer
    Last Post: 01-13-2005, 12:44 PM
  4. Voice Volume Level and "Voice"
    By dug1967 in forum FrodoPlayer
    Last Post: 12-30-2004, 01:56 AM
  5. Volume mute on mp3's when voice nav operational
    By Pabs in forum Media Engine
    Last Post: 05-25-2004, 07:50 AM
