Results 1 to 4 of 4
Thread: GPS memory?..
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    GPS memory?..
    Help!
    I have a Pharos 360 GPS; by default it works in NMEA, so I used SirfDemo to switch on sirf protocol. Everything works fine, except when I leave my car turned off for a couple of days... In that case, probably the inner memory of the GPS goes out of battery and lost even the "sirf" setting. So, when I turn it on again it is set for NMEA and of course MM doesn't find it.
    Is there any solution?
    Thanks in advance!!!
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Maybe you could use a macro tool to automatically run the sirfdemo software and set the GPS back to sirf mode on boot, or someone could write a little app to do automate this..?
    Jan 2005
    Milan, Italy
    This may be a problem, however, because I only hibernate my carpc and no app can run on wake up... I really prefer a way to permanently change working mode to Sirf!
    Oct 2004
    I believe if you do HORM (Hibernate Once - Resume Many) you can run specific apps on resume. Check the OS Optimization section for more info on HORM.
  1. Replies: 6
    Last Post: 02-04-2006, 10:22 AM
  2. FS: USB GPS Mouse
    By nappyjim in forum Classified Archive
    Last Post: 02-21-2005, 10:48 PM
  3. Replies: 4
    Last Post: 02-15-2005, 08:13 AM
  4. Best Pocket PC GPS Software
    By Danceheaven in forum GPS
    Last Post: 12-01-2004, 04:03 PM
  5. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
