Results 1 to 5 of 5
Thread: Number not found...
    May 2005
    Derbyshire, UK
    Number not found...
    I assume this is a limitation of the maps not of MapMonkey.
    On some UK addresses after entering the postcode and street it will say number not found so I can't navigate to there unless I zoom in on the map and manually select the destination. THis is no good if I don't know where the address is on a long road.
    Eg. S8 7, Lowedges road.
    Is this just my installation or is it others too ??
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    May 2005
    Derbyshire, UK
    Has no-one else had this problem ??
    Old setup
    New setup
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    this is, as you said a limitation of the maps you are using. Theres nothing you can do until newer maps are available.
    CdR
    May 2005
    Derbyshire, UK
    Cheers m8.
    I wondered if it was my maps. It is the latest version I think....3.0.75
    Old setup
    New setup
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    I have seen this a few times, i think that all addresses aren't entered into the database.
  1. Font Tahoma not found
    By clemen in forum Map Monkey
    Last Post: 06-13-2009, 02:47 AM
  2. Operating system not found... help!!
    By jol102001 in forum General Hardware Discussion
    Last Post: 03-23-2005, 12:46 AM
  3. Street data Not Found
    By Rikk in forum Map Monkey
    Last Post: 01-14-2005, 02:46 PM
  4. Font not found error message
    By tolisn in forum Software & Software Development
    Last Post: 11-23-2004, 01:24 PM
  5. Funny things found in 109
    By Don 944 LA in forum FrodoPlayer
    Last Post: 10-20-2004, 12:13 AM
