Results 1 to 5 of 5
Thread: On screen delay/stuttering with Map Monkey
    Low Bitrate Anees's Avatar
    Feb 2005
    UK, North West
    Hi guys,
    No luck after a so....
    When I am using Map Monkey the on-screen 2D/3D view is about 2 seconds behind my actual position. When I turn corners the map scrolls around very slowly too. This delay makes it hard to use in built-up areas with lots of close roads.
    My GPS reciever is a GPSlim236 using the SiRFIII chipset!
    My GPS settings are:
    Com5, NMEA mode 38400..
    Is there an obvious solution?
    Thanks for any help offered.
    Anees
    Feb 2005
    UK, North West
    I have also used MapMonkey with a bluetooth Fortuna Clip-on GPS based on SiRFII chipset with Xtrec2.02 and it also does the same thing.
    Is there some setting I have missed?? :??
    Feb 2005
    UK, North West
    So nobody has had this problem??
    Newbie halve85's Avatar
    Feb 2005
    i think everyone has this problem :-(
    Feb 2005
    UK, North West
    Quote Originally Posted by halve85
    Really??
  1. Map Monkey crashes after a while
    By superbowl in forum Map Monkey
    Last Post: 09-14-2005, 08:29 PM
  2. Map Monkey sdk center map command....
    By feelgood in forum Map Monkey
    Last Post: 05-28-2005, 06:31 AM
  3. Hide map monkey with girder
    By bigmac999 in forum FrodoPlayer
    Last Post: 05-09-2005, 02:18 PM
  4. Map Monkey Learns?
    By vxcarpc in forum Map Monkey
    Last Post: 05-04-2005, 11:57 AM
  5. Map Monkey POI updates, I need
    By gianal in forum Map Monkey
    Last Post: 04-26-2005, 02:20 PM
